2001 z06
Old Mar 6, 2013 | 01:47 PM
rickstso's Avatar
rickstso
Default 2001 z06
Hello, I just last week purchased a 2001 Z06 with a six speed. The car runs great but, I do have one issue. When shifting from 1st to 2nd, sometimes it just won't go. I have noticed if I keep pressure on the stick to the left, it shifts ok. Is this a common problem or I'm I just not used to it. The car only has 14,500 miles on it and drives like new.
Thanks in advance,
Rick:
Old Mar 6, 2013 | 01:52 PM
Ron C!'s Avatar
Ron C!
Maybe the CAGS working?
Old Mar 6, 2013 | 02:05 PM
3boystoys's Avatar
3boystoys
Read the OWNERS MANUAL.
Old Mar 6, 2013 | 02:07 PM
rickstso's Avatar
rickstso
Sorry but, what is the CAGS???
Rick,
Old Mar 6, 2013 | 02:10 PM
rickstso's Avatar
rickstso
Gee!, Why didn't I think of that!!
hklvette's Avatar
hklvette
Computer Aided Gear Selection. Basically, if you shift too late under a light load, it will try to make you shift to 4th. Supposedly, it has something to do with getting better fuel economy to avoid the gas guzzler tax. There should be a "1to4 shift" light that comes up on the dash when it does it. There are ways to get rid of that "feature," including changing driving style or purchasing a "CAGS eliminator"
Old Mar 6, 2013 | 02:11 PM
3boystoys's Avatar
3boystoys
All your answers are in there.
Old Mar 6, 2013 | 02:21 PM
rickstso's Avatar
rickstso
Thanks, I appreiciate your precise answer without all the BS. I will look into the CAGS elimator.
Old Mar 6, 2013 | 03:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Rick
Before you get too far off the track of the problem,, I agree,, the next time that you expierence the second gear issue,, see if the 1st to 4th shift CAGS is ON. If so,, it just a CAGS issue and perfectly normal. When you shift under LIGHT throttle, CAGS kicks in to save fuel.
When "hklvette" stated "There are ways to get rid of that "feature," including changing driving style" if you mash the throttle a little mor aggressively, the PCM will cancil the CAGS command!
I seldom had the CAGS intervention cause I drove it like I stole it.
Recommendation. if you DEATH GRIP the shift handle when you shift, its easy to shift from THIRD GEAR back to second.
If you ACCIDENTLY shift back into SECOND GEAR at Wide Open Throttle when your at 6000 RPM in third gear, the engine will mechanically spin up to some where close to 11000 RPM! That will NOT be a good event.
I ditched the stock shifter for a KIRBAN Shifter.
Bill
Old Mar 6, 2013 | 03:50 PM
rickstso's Avatar
rickstso
Bill, thanks for advise. I read the forums daily to learn about my new ride. Replies from guys like you are and will be helpful.
Rick,
To 2001 z06
