ls1 edit question
Old Jun 17, 2002 | 12:34 PM
abraham's Avatar
abraham
Default ls1 edit question
I am bouncing the rev limiter going from 2nd to 3rd on my a4. Just had h/c job and the rev limiter raised etc.. Is it a simple fix. What should I do? thanks
Old Jun 17, 2002 | 05:18 PM
K&B Motorsports's Avatar
K&B Motorsports
Default Re: ls1 edit question (abraham)
Unless you had a gear ratio change, you should not be hitting the rev limiter. What else did you have done ...etc.
Old Jun 17, 2002 | 05:40 PM
cjones's Avatar
cjones
Default Re: ls1 edit question (Buckmaster)
Easy change for LS1edit. In fact I could train a small animal to make that change with LS1edit.
To ls1 edit question
