Knock Sensor for 1999?
Old Mar 31, 2013 | 06:40 PM
Linaki's Avatar
Linaki
Cruising
Default Knock Sensor for 1999?
Hi guys!
My Vette is a 1999, and I just took the knocks sensors off (I am also changing my intake into an LS6). Does anyone know what brand is this knock sensor? I can't seem to figure that out..! What is the correct knock sensor? An AC Delco?
Thank you!
Lina
Old Mar 31, 2013 | 09:13 PM
_r2h's Avatar
_r2h
Check this link.
http://store.gmpartshouse.com/parts/...KNOCK%20SENSOR
Great vendor and can answer any questions you have about the proper part and get you an actual part number.
Old Mar 31, 2013 | 09:17 PM
69's Avatar
69
Cruise-In VI Veteran
Hello, since you are there with the knock sensor, check out this TSB
http://www.corvetteactioncenter.com/...+DTC+P0332+Set
Kevin
Old Apr 1, 2013 | 11:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Kevin
The knock sensor part number is included in the TSB!!
# 10456603
Old Apr 1, 2013 | 11:04 AM
Linaki's Avatar
Linaki
Cruising
Thank you both for your prompt answers! Seems that my k/s are an older model and not an oem part, since there is a white connector and there is no part number on it that matches GM.. I guess that might be causing the excess knock / false knock, plus there was much corrosion..
Old Apr 1, 2013 | 11:05 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
do yourself a favor and replace the harness while you are at it....don't ask how I know
Old Apr 1, 2013 | 11:08 AM
Linaki's Avatar
Linaki
Cruising
I can only assume you had problem yourself and finally the harness was causing it... I am planning to change it too, was looking at the Tick Performance kit that has GM sensors and GM harness.
Old Apr 1, 2013 | 11:24 AM
pewter99's Avatar
pewter99
yep....new knock sensors installed...a few months later the old (bad) harness took out both sensors....no knock sensors = call for more fuel...more fuel = washing down rings and oil consumption = crap all over the back of your car ....replaced harness and new sensors all good now
Old Apr 1, 2013 | 11:26 AM
Linaki's Avatar
Linaki
Cruising
Thank you for your help pewter99!
To Knock Sensor for 1999?
