Wheel stud question
Old Apr 7, 2013 | 03:31 PM
corvettedaddy11's Avatar
corvettedaddy11
Default Wheel stud question
Can wheel studs be replace or do I have to buy a new hub..?
Old Apr 7, 2013 | 03:41 PM
jamieo's Avatar
jamieo
They can be replaced but you need to remove the hub to press the new ones in.
Old Apr 7, 2013 | 07:01 PM
NukeC5's Avatar
NukeC5
I have a new set Im waiting for time to install. I know there are some write-ups floating around here.
Anyone have a link?
Old Apr 7, 2013 | 08:59 PM
Solofast's Avatar
Solofast
You can do the fronts on the car. Pound them out thru the holes in the backing plate and use a stack of washers (with some of them greased) and lug nut on backwards to pull the new stud into place. The trick is to turn the new stud so that the serrations in the new stud match the grooves left by the old stud. Do that and it'll pull right in.
To do the rears you have to take the hubs off, or you have to drill a hole in the rear backing plate to get the stud out.
Old Apr 8, 2013 | 12:01 AM
corvettedaddy11
2 studs in the right rear need to be replaces .
Old Apr 8, 2013 | 11:12 AM
alextz's Avatar
alextz
you need to pull the rear hubs to replace rear wheel studs. Some people have "cut" a window to allow you to replace rear studs without taking the hub off, but I didnt want to cut things.
you can replace front wheel studs without removing hub, there is enough room to pound out the old stud.
For your case of rear studs, the rear hub will need to come off. hardest part of the whole thing is popping the lower ball joint if you dont have the GM ball joint tool. If the wheel bearing is old, might consider putting a new one in as preventative maintenance.
To Wheel stud question
