Window alignment
Old Apr 15, 2013 | 05:38 PM
Damillio's Avatar
Damillio
Default Window alignment
Anyone local to Auburn able to assist with curing wind noise?
I'd rather not throw 2 hours of labor at the dealer
I've tried the adjustments I can reach without pulling off the door skin.
I'll supply the bottle of scotch (you can keep it too!)
Old Apr 15, 2013 | 11:48 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
window attaches to the reg. with 2 bolts/clamps, front/rear.........
The cable pulleys attach at 4 points, then you have the 10-15 C5 window/targa seals that are starting to rot/tear/etc.
I'd pull the door panel and start with the window glass clamps
Old Apr 16, 2013 | 09:42 PM
corvette77's Avatar
corvette77
Did the noise start all of a sudden, or have you replaced you regulator recently?
There are two rubber plugs underneath the door that you can remove. Inside is a screw to adjust the window. They are an E8 (reverse torx) I believe.
Old Apr 16, 2013 | 10:22 PM
Damillio's Avatar
Damillio
It has been going on since I bought the car last summer. It has gotten worse in my opinion, probably from dumb friends grabbing onto the window to shut the door. I have tried those adjustments with a little benefit.
Being in a apartment complex and studying full time for a doctorate precludes doing much more than that on my own time.
To Window alignment
