transmission advice
Old Apr 23, 2013 | 07:12 PM
soroZ's Avatar
soroZ
Default transmission advice
So long story short it seems like I have destroyed my mn12 transmission and I am in need of a transmission rebuild or a new transmission here are my current options and keep in mind I want to get the car back together as soon as possible.
1. Pay $2500 to a local shop who currently has my transmission and have them rebuild it with warranty including labor warranty.
2. Look for a used transmission I currently have found one for about 1300 shipped out of a totaled c5z06 with few upgrades.
3. Buy a c6z06 t56 for about 1600 locally.
4. Send my tranny to RPM to be rebuilt to a level 4 for $2500.
5. send my transmission to be rebuild for 1398 to tick performance to be rebuilt to their level 1 which has similar upgrades to a level 4 rpm transmission with a 12 month warranty.
To me the best option so far seems to be going with tick in my mind but I have not heard anything about the shop personally. Keep in mind I will not be keeping this transmission for long as I am looking to upgrade to a tr6060 within the year due to my power goals so I don't need a crazy build just something so i can drive my car for the next year.
That being said I am open to advise and suggestions what do you guys think?
Old Apr 23, 2013 | 07:22 PM
zeevette's Avatar
zeevette
Rick Kim. He's super fast, and good. RKT56.com
Old Apr 23, 2013 | 09:44 PM
DIXZ's Avatar
DIXZ
WOW! Tick wants 14 grand for the same rebuild as RPM for $2500? That is insane!
Old Apr 23, 2013 | 10:26 PM
soroZ's Avatar
soroZ
LOL i typed it in a hurry i meant 1400
Old Apr 23, 2013 | 10:39 PM
FourG63 97GST's Avatar
FourG63 97GST
used M12 and keep it moving, I wont build anything if I have a 6060 in mind.
sell that too, to recoup later.
Old Apr 24, 2013 | 12:05 AM
silver408z's Avatar
silver408z
Go used or do a tr6060 now. I personally really want a zr1 spec tr6060. Longer ratios in the lower gears and a 5th that is alot less of an overdrive than other gear stacks. It also depends on how much power you are making. Under 500 rwhp I would probably stick with c6z06 spec tr6060. I am over 700 rwhp and thats why I want the longer gears.
Old Apr 24, 2013 | 09:52 AM
soroZ's Avatar
soroZ
any particular reason to go with a c6z06 t56 vs the mn12?
Old Apr 24, 2013 | 01:54 PM
zeevette's Avatar
zeevette
It's considerably beefier, but you have to make alot of other changes to accomodate the newer one. However Rick can build a MN12 using 6060 internals that allows the upgrade without changing all the other stuff.
Old Apr 24, 2013 | 02:25 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
If the TR6060 is in your future, this would be the time to do it. It will save you a lot of $$$ in the long run.
C6 Z06 T56 has 30 spline shaft and the tailshaft housing is different.
We can build MZ6/MM6 TR6060 with custom overdrives with correct tailshaft housing so it will be a direct bolt in for a C5.
__________________
Old Apr 24, 2013 | 10:00 PM
soroZ's Avatar
soroZ
so you are saying it will not bolt directly to the c5 rear end?
I would love to but I definitely dont have the close to 8-10k needed for a proper tr6060 swap with differential and all the modding needed so it has to wait.
Old Apr 24, 2013 | 10:23 PM
Supporting Vendor
The C6 Z06 has 30 splined main shaft and the mating bolt pattern is different (5 fasteners C5 compared to 8 for C6).
PM sent.
To transmission advice
