Completely torn with decision on new engine
Old May 1, 2013 | 04:41 PM
racebum's Avatar
racebum
Originally Posted by animuL
I see your point, but I drive an average of 3000 miles a year, so it would take 67 years to go 200k . Considering that, either option is viable. Also I'm looking at reasonably mild cams with lift at or under .600 so I don't see any reason why the built setup would be life limited. Either setup will be 10.5 to 11.0 static compression ratio.
PWC clearance is greater on a forged piston. higher rpm and less ring tension coupled would greater clearance typically means more oil being burnt, but, you have a motor that can take a lot more bang
if you're staying with a mild under 600 lift cam and not revving over 6600 i would stay with cast. they are quiet, live forever and don't burn oil.
depending on your hp goals you might be able to just use a late model ls1 bottom end with some ported 243 heads and have a strong street car
440 hp at the wheels has been done more than once with a stock bottom end, also would be an inexpensive build
Old May 1, 2013 | 04:44 PM
animuL's Avatar
animuL
Just came across this: http://www.slponline.com/view_produc...asp?P=12535M24
Will LS1 oil pan and engine covers fit on an LS3?
Old May 2, 2013 | 09:43 PM
animuL's Avatar
animuL
Well I finally made a decision, ordered a TSP 408 Long block with PRC 237 heads and Ed Curtis cam. Should be a fun daily driver!
Old May 3, 2013 | 03:18 AM
efrenwyman's Avatar
efrenwyman
8th Gear
I think you have made a great decision by ordering a TSP 408 Long block with PRC 237 heads and Ed Curtis cam. Really hope you will have a great experience with this new engine.
