My 99 C5 m-6 Z-51 coupe with 77,000 miles developed a strange knock when turning off and on a few weeks ago. Drove fine, smooth, no low oil pressure, no hi temps. I took off the serpentine belt, and the noise was still there. I took it to my mechanic, and he called me when it was in the air to take a look. There is some oil coming out of the rear main, but you can grab the flywheel and rotate it both directions about a half an inch without any resistance. Flywheel to crank bolts are tight. He said that the only thing that would cause that is a broken crank in an angled fashion at the rear hub. I've never heard of a broken crank on a bone stock LS1. Anyone else?
Hi,
did you have any detonation issues,or any other reason to have bad harmonics(vibrations) in the engine/drive line?
I broke a crank in a 302 ford (built)not too long ago and I never heard of a crank breaking either. It did run but knocked very badly. It was from the balancer and the essentric slipped and vibrated the crank apart at the counterweight.Not an LS1 but I imagine it could happen given the proper variables.
Many years ago a car came to my father's repair garage that had the crank broken on an angle. It ran but did have a knock in it when you backed off on the throttle or shutting it off.
One of my co-workers had this happen to a Mercedes a number of years back. I believe the car still ran with it so I think the potential is there for any car and as stated by Jay-rod you may have some conditions that were the root cause. The harmonic damper condition or if aftermarket manufacturer, may be a major contributor. I would check that as well.
I doubt its broke, it probably needs a new timing chain though. That is about how much slop is in a stock timing chain when checked that far out from the center of the crank. Have him check the end play on the flywheel, if its broke it will move in and out since the thrust bearing is on the middle journal of the block. If the timing chain is a issue (it was for me), consider a Roll Master timing set, it tightened mine right up.
Reason: typo
