Hard Starting 2004 Z06
Old May 3, 2013 | 02:49 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Default Hard Starting 2004 Z06
Hi all!
This is my first post on here regarding my new-to-me 04 Z16 Z06. It has 30,000 miles on it and is in great shape.
The only thing that I have noticed is that it takes about 5-6 seconds of cranking before the car fires and starts.
This only occurs in the morning, when the car hasn't been driven for 10-12 hours. During the rest of the day it starts after about 1-2 seconds of cranking.
I have tried priming the fuel system by turning the key to "ON" but not starting it, several times. This seems help with the problem.
Before buying this Vette, I had a LS1 Camaro for 9 years, so I am pretty familiar with GM's F-body platform and the LS1/LS6.
I guess the question is, why do I have to prime my Vette when my Camaro LS1 would start on the first crank and the Vette starts fine during the day?
Is there a leak in the top end of the fuel system that is allowing air in while the car sits over night?
PS I have not pulled codes yet, but will try and do that when I get home tonight.
Old May 3, 2013 | 03:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is a very small fuel line check valve inside the fuel line near the tank. They have been known to go bad and allow all the fuel in the line to drain back to the tank thus causing LONG CRANK TIMES. The fuel pressure gage will tell you good solid info but, even though you see PRESURE at the gage, make sure that its not pressurized AIR in the line.
If you press the shrader valve on the front of the driver side fuel rail, you should immediatel see presurized fuel.
YOU ARE CORRECT. Your car should fire right off without extended crank times.
Old May 3, 2013 | 03:54 PM
gun5l1ng3r's Avatar
gun5l1ng3r
What would be the fix for this?
Can I replace just the valve by uhooking the fuel line at the tank, or do you think this will require a whole new fuel line?
Maybe some Techron?
Old May 3, 2013 | 04:32 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Originally Posted by 8VETTE7
This may be correct for the NON-FFS fuel system. However the OP says he has a 2004 Z06 so he has an FFS Fuel System.
The check valve is a part of the pump assembly in the tank. Part W in the following link/diagram.
http://xlr-net.com/kb/questions/44/
If the check valve is failing then repair is NOT a simple procedure as the pump assembly cannot be removed on the FFS sysem without dropping the left side tank.
Before I went to the trouble of dropping the tank I would exhaust all other possibilities. JMHO.
I do have a 2004 for sure.
What other options might you look at? Check all of the fittings to make sure there are no leaks allowing the fuel to drain back?
I think if it was the check valve, it would still be hard to start in the middle of the day...
Old May 3, 2013 | 05:55 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Certainly checking all the connection points would be a step(s). Some under the car at or near the tanks are going to be difficult to get to but there may be fuel stains if you can get the car on a lift to check. It could be one or more injectors that are leaking down as well. Check the dipstick and see if the oil has a strong fuel smell. Do you have any cloud that eminates from the exhaust when you start it in the morning (cold)? What color if there is a cloud?
There is no cloud, but I do have the normal condensation effect out the back on colder mornings. The color is white.
How else would I check for a leaky injector other than taking them out and having them tested?
The dipstick doesn't smell strongly of fuel.
Now I am worried about a washed down cylinder
Old May 3, 2013 | 06:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks for providing the correct info. Them damn 2004s
Bill
Old May 3, 2013 | 09:22 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Thanks 8VETTE7
I hope someone else might chime in with any experiences similar to this one...
Old May 3, 2013 | 09:46 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Alright, I went and pulled the codes from my IPC and this is what I got (all of them)...is there a thread/website that shows all of the codes for a 2004? I tried searching with no luck...maybe you can decode them 8VETTE7.
B0367H
B2283H
B2287H
B2285H
B2282H
B2286H
B2284H
U1064H
U1096H
I think the U1064 and U1096 have something to do with a ground on the bottom of the block, but it seems from another post that it is inaccessible.
Also, I think the B0367 has something to do with realigning my actuators in the HVAC system...
Thanks again guys!
PS I have owned the car for about 2 months, so I have cycled the ignition at least 50 times and the codes still show as "H", which tells me these have happened recently...
Old May 3, 2013 | 10:13 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Actually I have to get my car smogged here in California in the next couple days...
I will wait until afterwards to reset the codes. Why shouldn't I clear the codes before a smog test?
Old May 3, 2013 | 10:22 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Thanks!
I have lurked on here for a while and am humbled to get my first post answered by the infamous 8VETTE7
Old May 3, 2013 | 10:31 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Don't be humbled by my responding... I don't hold a candle to the likes of Bill Curlee and several others.......... Glad to offer some help as are the other on this great forum
The Corvette family seems a little nicer than the Fbody crowd...
Now I just have to perfect my Vette Wave
Old May 3, 2013 | 10:32 PM
bobby777's Avatar
bobby777
Ill bet that is what it is as mine did the same thing--valve in that line gets plugged--
Old May 3, 2013 | 10:48 PM
gun5l1ng3r's Avatar
gun5l1ng3r
How did you get it unstuck?
Did you drop the fuel tank?
Old May 3, 2013 | 11:40 PM
bobby777's Avatar
bobby777
You don't--that line blocks some fuel from going to the tank and is always under pressure--so when you start when cold the fuel is there-for a quick fire up--goes from the fuel filter to one of the tank pumps--I think you need a pro to do it--BTW the line is like 150.00 if I remember right some years ago-that I think is your problem
To Hard Starting 2004 Z06
