99 suburban corvette engine swap
I have progressed in my quest for the LS1 dropin to my 99 Suburban 2 WD. I am going to hook it up to my 4L60-E after freshen up and upgrade to 4L65-E. Looking for someone in Richmond VA area to do that.
Think I can get a handle on the front setup, AC, generator, PS, water pump etc. Need to find headers that will fit and add Hp. Intend to use LS1 stock intake to start, with cable drive throttle body. This is where I run into doubt, what can I do with the throttle body, MAS, cold air intake etc. to add Hp - cost is a factor; and how does this effect tuning.
Tuning is the black hole for me and I could use advice on where to start to integrate this motor to my Suburban and have both run; fast with daily driver reliability..
I think I have coil packs (what, more than one coil - what's this world coming too) and coil wiring harness, and I have a used low mileage engine harness from a 2002 Trans Am with 4L60-E. I need to know where to hookup this harness et al. I know someone is going to tell me where to shove it, but I'm just asking for help.
I can offer help on 68 69 Vette body off restorations and parts ID in return.
That's enough for this post: Hope replies keep me busy - Thanks
I just saw a program where GM offers a drop in crate engine/trans/electronics so all you have to do is drop it in anything, turn the key and go. Since you haven't really worked on modern drivetrains, this may be a better option for you.
http://www.chevroletperformance.com/...train-systems/
I beginning to wonder if I am in the wrong forum: I have owned four vettes, 67, 68, 69, and 90 ZR1 and was re-living my fun by communicating with other vette owners. Also thought I could get some sound advice on bolt-on Hp and other vette tricks before dropping the LS1 into my loved suburban, but "How fast will a Suburban go?" Is a strange answer. My 97 Cobra with a set of gears lit up a few vettes and I'm sure if I mess with my LS1 a little bit, my suburban will surprise a few more. Oh well, stop light to stop light is still my passion
http://www.google.com/search?sourceid=navclient&aq=&oq=ls1+in+a+suburban&ie=UTF-8&rlz=1T4GGHP_enUS423US424&q=ls1+suburban+swap+&gs_l=hp..1.0i22i30l2.0.0.0.7142...........0.Oj3_1q6hsMg
or better yet:
http://www.ls1truck.com/forums/lsx-t...n-ls1-2-a.html
OR
http://www.amazon.com/s/?ie=UTF8&key...l_4syb7rpwww_b
