Cuts out Under WOT, help
Old May 25, 2013 | 12:29 PM
03Zcrit's Avatar
03Zcrit
Default Cuts out Under WOT, help
Hello All, I just purchased an 03 z06 and of course a few days after it starts acting up. If I quickly go to WOT the car will accelerate to about 5k or so then the engine will cut as if I quickly took my foot off the pedal (or like the fuel or spark has been cut) and it won't re-engage until I take my foot off the pedal then re-apply, anyone heard of this? I can take the car to redline and it pulls great if I don't give it WOT.
Old May 25, 2013 | 01:31 PM
03Zcrit's Avatar
03Zcrit
Thanks, tried that but no codes came up. I am going to change the plugs and wires because I don't know the history on them and they may be original with 62k miles
Old May 25, 2013 | 05:50 PM
Cybermind's Avatar
Cybermind
Check for vacuum leaks. I went through a similar issue and it ended up being caused by an air leak between the PCV and the intake manifold (small hose).
Old May 27, 2013 | 02:02 AM
03Zcrit's Avatar
03Zcrit
Thanks Cybermind, I'll check all the hoses going to and from the manifold.
Old May 27, 2013 | 01:48 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Check the to sensor. Graphing it would be good. See if it has any drop outs or spikes. It should read over 4.0 volts at wot.
Old May 28, 2013 | 10:57 AM
TBH94's Avatar
TBH94
This may sound crazy but is the traction control kicking in? Tire spin? Try shutting off the traction control and see if anything changes.
Old May 28, 2013 | 11:01 AM
03Zcrit's Avatar
03Zcrit
Not getting a traction control indication on the cluster so probably not. I just put in a new set of plug and destroyed one of the old wires taking them off so will have a new set tomorrow and will try the T.C. off in case the plugs and wires weren't the problem.
Old May 28, 2013 | 12:51 PM
Cybermind's Avatar
Cybermind
Keep in mind that normally, a misfire will cause the check engine light to flash. If you're not getting a flashing CEL or code, then it probably is not a misfire (caused by bad wires or spark plugs). It's always good to change the plugs and wires but, I still think you may have an air leak somewhere after the MAF.
Read my previous posts regarding my stalling issue. Not only was my engine sporadically cut-out but actually stalling at highway speeds. It would start right back up as if nothing happened. I had no codes and was ready to give up until I found a loose PCV hose right by the throttle body. It was barely hanging on. I replaced that and voila! My car has never driven better.
By the way, it cost me a new MAF and ignition switch before I found the real culprit. Oh well, it was a learning experience for me.
Old May 28, 2013 | 09:34 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Sorry, that should have read tp sensor. I did not catch the typo.
Old May 30, 2013 | 02:51 AM
03Zcrit's Avatar
03Zcrit
And the winner is.......
The previous owner had installed a smooth silicone connector going from the air bridge to the throttle body and got a bit overzealous on the hose clamps and there was a small gap in the air bridge that I think was what was causing the problem. You called it cybermind!
Old May 30, 2013 | 06:24 AM
Cybermind's Avatar
Cybermind
Glad it worked out for you!
Old May 30, 2013 | 09:22 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Marty
Our C5s are Throttle By Wire and EXTREMELY critical when it comes down to Throttle Position Sensor operation.
If ANYTHING is wrong with the TAC, Throttle Position Sensor or Accelerator Pedal Position Sensor, it will set a DTC and frequently sets the PCM into (REDUCED POWER MODE).
BC
To Cuts out Under WOT, help
