USED Blackwing, modify the radiator shroud for cold air. $150 and 2 hrs work. Cheap CAI as true as any other CAI that takes in outside air.
Is that cover a piece you can purchase? My car came with a Blackwing and I'd like to get it altered to pull in cool air before I get the car tuned. Thanks.
Team ZR1 has them for about $165. There are other vendors. You can also Google "Blackwing Icebox retailers" for the best price. It's a must to have a "real Blackwing CAI." It's just as "real" as the Honker,Hurricane, or Vortex Rammer.
That looks great. How about a little more information though. What did you make the top cover and the bottom scoop out of?
The top cover is the IceBox. The scoop I found in a parts bin at a swap meet. But a plastic wall folder from Office Depot will also work as a good plan B for the underside scoop. Its a great mod, it pulls harder,and the engine temps are lower as well as slightly better MPG. It's much cheaper than the $500+ for the Honker, same "real/true" result.
