2000 Cabin Pressure Problem
Old May 27, 2013 | 10:57 PM
2000tred's Avatar
2000tred
Cruising
Default 2000 Cabin Pressure Problem
My 2000 has a problem venting cabin pressure. If I leave a window down or a door open the rear hatch will glide shut. When I have doors closed and windows up. I have to slowly put it down then press it shut. I experimented by leaving the driver door slightly open and closing the rear hatch. When I did it had so much pressure that is almost blew the door half way open. The doors even have some resistance to them. I have checked the cabin vent in the rear drivers side cargo area. It was clear and free of any restrictions. Is there something I may have overlooked?
Old May 27, 2013 | 11:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The cabin air release is in the rear hatch area. In the LEFT (drivers side) rear fender well, pull down the carpet in the stowage well area and you will see the vent louvers. They have a rubber sheet flap that acts as a one way (OUT) check valve. Make sure that they are not stuck shut / clogged/blocked or damaged.
Old May 28, 2013 | 12:17 AM
2000tred's Avatar
2000tred
Cruising
Hi, I have checked the air release. The flaps open and close good and didn't feel like they were sticking, or had any restrictions.
Old May 28, 2013 | 12:50 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
simply open the door before shutting the hatch...takes a few seconds. too much air volume for the pressure relief valve to work properly
Old May 28, 2013 | 01:15 AM
onlyavette's Avatar
onlyavette
I thought we were supposed to lower the rear hatch slowly and then finish closing it by pushing down on the logo (if it is still on) until it latches.
I don't recall any problem closing the rear hatch. How do you close yours?
Old May 28, 2013 | 01:42 AM
2000tred's Avatar
2000tred
Cruising
I Lower it by letting it down and pushing down on the emblem. I"m in the local Corvette club, and have noticed the other c5's trunk lids will glide shut, with the windows up and doors shut. They let them down about half way then they simply let them go and they glide shut completely. Mine will do the same only if I put a window down or open a door. It's not a big problem I'm just trying to figure out why mine won't do it. I have also greased the door and cargo latches.
Old May 28, 2013 | 02:00 PM
Evil-Twin's Avatar
Evil-Twin
The coupe will draw more air volume than the Z06 or vert. The care taken to lower half way and allow to close slowly is about exchange of air volume. With the door open or a window open you can effortlessly close the hatch. the trunk relief valve can handle a relatively small amount of air. the slow process mentioned above from others works fine , but for others it does not. I would rather not tempt the rear glass seal especially the hatch seal to being forced to blow out ( and it will leak ) if you don't equalize the pressure properly. opening a door while closing the hatch will insure this will never happen.
Old May 28, 2013 | 06:11 PM
2000tred's Avatar
2000tred
Cruising
Did later c'5s have larger vents. I called up a club member that closed his that way and he said his was an 03 model. Could it be GM changed the vent size?
Old May 30, 2013 | 12:38 AM
2000tred's Avatar
2000tred
Cruising
I called the local dealer and they informed me that all C5's have the same vent. So I am going to leave it as is. It may be that mine has a tighter seal then the others I have seen. Thanks to everyone for all your help and suggestions.
Old May 30, 2013 | 09:44 AM
SaberD's Avatar
SaberD
i still shut the door to pop my trunk up haha. i need to get that trunk lid assist spring.
Old May 30, 2013 | 05:24 PM
1sickz51vette's Avatar
1sickz51vette
Hmmm speaking of cabin pressure, has anyone ever had their side windows bow out while at higher speeds on the track? My friend was like holy crap man the window is bowed out at high speeds! I also have the same hatch issue with my 97', Will have to check the vent asap.
Old May 31, 2013 | 11:07 AM
SaberD's Avatar
SaberD
there are some adjustments in the door that allow you to adjust the angle of the window and thus the pressure on the window seal. I need to readjust mine. I have the same issue. pretty common.
To 2000 Cabin Pressure Problem
