Trouble Shooting electrical problem
Old May 28, 2013 | 05:54 PM
coryk7171's Avatar
coryk7171
1st Gear
Default Trouble Shooting electrical problem
Anyone have any idea what would cause "charging system failure" to come on the dash, car to break down and not start for roughly 20 minutes, then is able to start when hooked up to jumper cables and drives normal after. anything ring a bell?
Old May 28, 2013 | 11:25 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
alternator failure.
Old May 29, 2013 | 11:49 AM
tacman's Avatar
tacman
St. Jude Donor '13
Default Troubleshooting Electrical Problem
There are a number of people that can help you with this. I am probably not one of them, but the first question they will ask is "...any codes?"
Old May 29, 2013 | 01:28 PM
dadaroo's Avatar
dadaroo
Alternator and/or associated ground issue. I have seen a post on charging issues caused by a bad ground. If I recall the ground is near the battery, but below it. I can get you more info if you need, just not home now.
Old May 29, 2013 | 01:43 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Sounds like an alternator problem, you can easily remove it in 5 minutes and take it to a parts store for testing.
Old May 29, 2013 | 01:45 PM
3boystoys's Avatar
3boystoys
Test BATTERY FIRST, a bad battery will DESTROY an alternator quite quickly. Then get a voltmeter out and test the output voltage. I have found bad alternators that test GOOD at the parts store many times. The only GOOD way to test an alternator is with a scope or graphing voltmeter to make sure your getting clean (almost DC) out of the alternator. I'm betting your battery is TOAST, better hope it hasn't taken your alternator with it.
Old May 29, 2013 | 05:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CAll me........ PM SENT!!! I cant TYPE everything that you need to do to resolve it right now but, 10 min on the phone and you will be all set!
To Trouble Shooting electrical problem
