Whats wrong with my rearend????? help!
2000 A4 coupe with 85K. 3 weeks ago had a 4 wheel alignment done at the dealership and was told the rear was visibly off. They did the alignment and all felt fine (was told that all wheel bearings felt good along with tie rods and other suspension parts). I then took a trip from Michigan down to the Tail of the Dragon and all went smooth. On my way home I noticed that every time I hit a patch in the road or a rough seam, like at a bridge, the rear end felt like it was jetting out from under me. There were a couple time that it actaully made me grab the wheel with both hands... Now at lower speeds you don't feel anything but at highway speeds it really gets your attention... but only when hitting a bump or something. It doesn't feel like the rear is dog walking or anyting while on smooth surfaces and the car doesn't pull left or right... its just when you hit a bump and upset the suspension.
What the heck could be going on??? Is it possible the alignment is out again? Is it a sign of worn tires (I did notice the rears are starting to wear a little un even (Pilot Sports))? I'm thinking about taking it back in for another alignment check and suspension inspection but I hate to pay dealership prices... especially when it turns out to be something I can do myself.
Any thoughts / suggestions on where to start before heading back to the dealership?
Thanks,
George
Thanks,
George
Sounds just like what happened.
Examine the cams in the front and real and see if any of them are SIGNIFICANTLY different than the rest. All the cams in the same symmetrical location should be somewhat close to each other position wise. If one side is significantly different, there’s your issue.
Is also possible that something could have failed. Look at all the geometry support stuff for something out of whack.
Have the shop recheck the alignment.
BC
Agree you should take it back, there should be no charge!
Ron
Anyone have any pictures of these alignment cams so I can mark them? I'm good around the motor area but suspension is all foreign to me.
I also just made an appointment to have the alignment rechecked / corrected.
Thanks for all the insight guys,
George
Bill
I went to an alignment shop to get an alignment.
An Official "GOODYEAR" shop.
A month later I heard a "clunk" from the front every time I turned right or left.
I lifted the car and found one of my lower A arm bolts just about to fall off !
I went back to the shop with the Torque specs printed out, and told them about the loose bolt. I asked them to re-do the alignment using the torque specs.
They said "torque specs are not that important".
... I'm not kidding.. that was word for word. I raised my voice a little
in the waiting room where all the other customers were.... "What do you mean torque specs are not important ??? Is'nt that why my suspension almost fell apart and crashed my car ?" "It could have killed me if I was on the highway"I just walked out and said I'm never coming back.
Toque
Really just glad its all fixed.
