Need some help with failed window/lock switch
Old Jun 1, 2013 | 06:18 PM
04MSZ06's Avatar
04MSZ06
Default Need some help with failed window/lock switch
I'm out of ideas. I just replaced my driver side window regulator and reconnected the switch panel to find that the doors won't lock and the windows won't roll up or down. The crazy thing is I can move both mirrors just fine. I replaced the fuse for the LDCM (#33) and still no luck. The only code it's throwing is a U1160 H code. Key fob unlocks both doors fine and the passenger side controls lock and unlock both doors as well.
Old Jun 5, 2013 | 01:50 PM
04MSZ06's Avatar
04MSZ06
TTT...shook the wires inside the wire protector that goes from the door to the body and still no luck. Can somebody shed some light on this?
Old Jun 5, 2013 | 02:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Pop out the accordion tube and disconnect both connectors. Inspect all the pins Look for bent/burnt/deformed female pins. Repair as necessary. Reconnect and try again.
Bill
Old Jun 8, 2013 | 03:17 PM
04MSZ06's Avatar
04MSZ06
Popped out the wires in the accordian thing and inspected them. Still no luck. Jiggled the wires all throughout and nothing as well. I'm not getting any codes now either. I replaced the door control module with one I bought from someone on here and same thing. I can move the mirrors but can't lock the doors or roll the windows up. Is it a bad switch?
Old Jun 8, 2013 | 04:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The DCM has TWO fuses. You need to physically check BOTH. Make sure that they are in good shape and not loose. Make sure that there is power at both fuses with a METER. Measure the same voltage at the plug on the DCM and make sure that it is full battery voltage.
DCM-L Mini fuse 33 10 amp
PWRFDL Mini fuse 34 25 amp
Old Jun 8, 2013 | 04:19 PM
04MSZ06's Avatar
04MSZ06
I'm on it. You're the man Bill!
Old Jun 8, 2013 | 04:49 PM
04MSZ06's Avatar
04MSZ06
Ok I nailed it! By sheer curiosity I plugged the passenger side switch into the drivers side DCM and now it works (window rolls up and down and doors lock). So I'm down to either the wiring or switch assembly.
Old Jun 8, 2013 | 07:04 PM
04MSZ06's Avatar
04MSZ06
Can anyone confirm if a window/lock switch with memory will work in a C5 without memory? I can't believe GM charges over $400 for this.
To Need some help with failed window/lock switch
