LS3 Engine Swap Info
Old Jun 15, 2013 | 11:07 PM
ibeheretoo's Avatar
ibeheretoo
4th Gear
Default LS3 Engine Swap Info
I'm gathering information on what would be necessary to swap a LS3 Crate Engine into a C5. So far this is what I've been able to find.
Throttle Body, GM 12570790
Throttle Body Adapter, Casper Electronics 108115
Fuel Injector Adapters, Casper Electronics 109077
Knock Sensor / Cam Sensor Harness, Casper Electronics 109081
MAP Sensor Harness Extension, Casper Electronics 109080
So the big question is about the Reluctor Wheel. I know many have used the adapter sold by Lingenfelter Performance. What parts would be needed to change the wheel instead of using the adapter?
Old Jun 16, 2013 | 12:08 AM
superramvette2's Avatar
superramvette2
I have the lingenfelter box for ls7 and it works flawless. Also may have different pilot bearing , the ls7 did.
Old Jun 16, 2013 | 12:22 AM
LoneStarFRC's Avatar
LoneStarFRC
Default I recommend
Racetronix MAP sensor extension LS2-MSEH $25.00
http://www.racetronix.biz/itemdesc.a...2DMSEH&eq=&Tp=
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxx
Racetronix Cam sensor adapter harness LS2-CSAH OR LS2-CSAH-2 (take your pick of correct style, same price each) $19.00
http://www.racetronix.biz/itemdesc.a...2DCSAH&eq=&Tp=
OR
http://www.racetronix.biz/itemdesc.a...AH%2D2&eq=&Tp=
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Racetronix Injector adapters RCS-039 $4.95 ea.
http://www.racetronix.biz/itemdesc.a...%2D039&eq=&Tp=
Racetronix Throttle Body adapter harness LS2-TBAH $42.50 (Truly sealed unlike Casper's)
http://www.racetronix.biz/itemdesc.a...2DTBAH&eq=&Tp=
Racetronix Knock Sensor extension harness LS2-KSRH $22.50
http://www.racetronix.biz/itemdesc.a...2DKSRH&eq=&Tp=
Casper's total = $200.45
Racetronix total for same items = $148.60
Racetronix is a CF sponsor and no, I do not get anything from them. I use and like their products very much. Not China, made in Canada. Once you use their stuff you will too.
Old Jun 16, 2013 | 12:24 AM
LoneStarFRC
OP:
Which intake manifold will you be using? LS3 or FAST? How about fuel rail?
Old Jun 16, 2013 | 12:29 AM
ibeheretoo's Avatar
ibeheretoo
4th Gear
Planning on using the LS3 intake manifold and fuel rails.
Old Jun 16, 2013 | 01:01 AM
LoneStarFRC
How about injectors? The LS3 injectors have two different sized o-rings.
Good call on the TB too btw:
http://forums.corvetteforum.com/c5-t...er-blades.html
Old Jun 16, 2013 | 01:45 AM
ibeheretoo's Avatar
ibeheretoo
4th Gear
LS3 Fuel Injectors
Old Jun 16, 2013 | 02:04 AM
LoneStarFRC
LS3 Fuel Injectors
I went through a lot of this when I did my swap except I didn't have to worry with the reluctor wheel aspect. Later on, I had a problem with a Casper's connector not being sealed and it almost left me stranded. Switched to Racetronix and have been happy ever since.
Btw, I'm not sure if Pete Incaudo is still porting TBs, but if he is, I'd highly recommend sending your new one to him. He IS the man when it comes to TB porting done correctly and he's a hell of a nice guy on top.
www.vmaxmotorsports.com
If he's not selling direct, contact: http://www.mikenorrismotorsports.com/
Mike sells Pete's TBs. It's worth it.
GLWYB
Old Jun 16, 2013 | 09:58 AM
ibeheretoo's Avatar
ibeheretoo
4th Gear
Thanks for the information you've provided.
To LS3 Engine Swap Info
