taillight, dashboard, headlight movement gone...
Old Jun 24, 2013 | 12:47 PM
Z06seal's Avatar
Z06seal
Default taillight, dashboard, headlight movement gone...
I changed my turn signal light bulb (front passenger) because it had blown out.....
I get back in the car, try to put down my headlights, and they don't respond. then I realize I also lost my tail lights and my dashboard lights....
I did some research and found out this can be a multi-stalk issue....
I'm just so baffled. it was working JUST fine before I changed my light bulb. how can I lose my multi stalk like this?
I thought maybe I snagged on a wire by the headlight control module, but it doesn't seem like it. also I don't think it would affect the dash lights in that case....
any suggestions guys? What could have possibly caused this?
Old Jun 24, 2013 | 03:35 PM
Z06seal's Avatar
Z06seal
Originally Posted by 8VETTE7
Did you check fuses in the IP Fuse box in the passenger foot well?????
I just checked the IPC fuse, it's good.
not sure how all the fuses related to those specific things can just all go out at the same time. any specific fuses I should check?
the dashboard does light up when there is a key inserted.
Old Jun 26, 2013 | 07:16 AM
Z06seal's Avatar
Z06seal
is there anything in the passenger wheel well/headlight area that I could have kinked (wire/harness) that could have caused this?
Old Jun 26, 2013 | 05:28 PM
rkdc5z06's Avatar
rkdc5z06
I had similar problem where my tail light, dash light, turn signals didn't work. (Brake lights work)
you might need to get signal & criuse control switch replaced. I just got mine replaced and now its fine.
here is a link HOW TO
http://forums.corvetteforum.com/c5-t...-a-how-to.html
Old Jun 26, 2013 | 05:43 PM
Z06seal's Avatar
Z06seal
That's what I've been seeing, but everything was working fine before I switched the light bulb. I'm just baffled at the timing, and would hate to spend 130 bucks if it's something else.
everything points at it though. I mean what can be by the passenger headlight that would cut out power to my dashboard lights?
Old Jun 27, 2013 | 04:46 PM
Z06seal's Avatar
Z06seal
I just replaced my stalk and still same problem... it's something else.
somebody... please chime in. i'm desperate here. I can't drive my car at night!
Old Jun 27, 2013 | 05:28 PM
Z06seal's Avatar
Z06seal
Thanks to the internet, my searching abilities AND google caching, I found a thread where someone had the same problem! it's the #6 fuse under the pass footwell. PK/TLP
http://webcache.googleusercontent.co...&ct=clnk&gl=us
Old Jun 27, 2013 | 10:03 PM
byronhunter's Avatar
byronhunter
Hmmmmmmmmm, Where did I see a recommendation to check the fuses in the IP fuse box???????
I saw it!!!!!!!
Old Jun 28, 2013 | 01:40 AM
Z06seal's Avatar
Z06seal
I thought you meant IPC in that fuse box!!!!! I don't even know what IP is (inside passenger?) LOL!
To taillight, dashboard, headlight movement gone...
