DIC resets on every start up
I recently got a new battery and installed it. Since I have had the steering wheel column lock (I have anMN6 and GM did the recall) so now I have to install the CLB (remove the recall) and but I have also had problems with my DIC reseting every time I turn the car on. What could be the cause of this I have a brand new battery!
Thanks in Advance.
You have a 12 VDC power issue somewhere and its most likely a bad connection or defective batteryIf you have a DC Volt meter, put it directly on the battery terminals and have someone crank the engine while you watch the voltage reading. If its a new battery, it should NOT drop below 11 ish volts.
If it drops lower than 10 VDC, the battery is having issues.
BC
