Thanks, I know I can get better results, but my time slips are what Im actually looking forward to. I would rather dyno on less than ideal conditions to know that my car will perform this well or better at all times. Not good at one time and less the rest of the time.
I know you know what Im talking about. You seem like a pretty smart guy from posts in any threads I've read of yours
Thanks, I try
Glad you got a sense of humor as there are some real inconsiderate posts lol
In all seriousness, the ~100hp you gained at the crank should be worth ~10mph in the 1/4. From what I've experienced that translates to ~60% in the 1/8, so you should gain ~6 mph weather being equal.
I wont know until I hit the track I guess. I will also be racing with a complete Pfadt drag suspension as mentioned. That may make a difference too.. maybe i should race without it first to see what the engine alone did...
I wouldn't think it would affect mph unless it saves weight. MPH will show the HP gain.
ET is all about hook.
I believe you said the track you run isn't a real full time dragstrip?
BTW...I ran a kid in a 2013 M5 a few weeks ago. Reminded me of you and the Beemer you were tussling with. The kid wanted me. I beat him by over 10 car lengths. He follows me down the return road flashing his brights, pulls up to my pit spot and tells me I left too early and he wanted to try agian. Too funny. I had a .005 light.......11.25 to his 12.90. I said not right now...maybe later.
beamers, not a fan. I'm glad you made him look like a fool!
I was more wondering how a 20 something kid afforded a car like that. He clearly knew nothing about cars......or how to drive his. They actually should run low 12's.
Just got done with the H/C swap and tuning. Though Id share the results. Before the swap, I was at 304whp/291wtq.
Cam installed was a custom grind 220/228 .578/.586 on a 115*LSA. Heads are fully ported 243's by WCC, w/ stainless steel valves and decked to 63cc.
Final readout was 387whp/337wtq. The cam was not exactly what I wanted, but I am impressed with a 83whp increase and 46wtq to say the least. I wanted a 222 or 224 int. and 114 LSA. But the specs are very close and I will have no trouble passing the sniffer here in Cali.
Still have yet to do long-tubes. So easily a 400whp car if I go that route.
This is what its all about ..... the net change. Doesn't matter if its uncorrected, mustang dyno or not. As long as you run it on the same machine before and after you know the true change The 3200 is going to make for some fun.
Nuke who did the tuning? and where did you get it dyno'd? If you took it to CMS I seriously doubt you would get 430 they changed to a Mustang dyno and that read lower than their old Dyno Dynamics ( that is ofcourse is if you were chasing numbers) heck man it could be the tune but we won't get into that lol. glad to see you are upping the power it should make for some better times at the track. Which track are you going to, the parking lot strip or out to barona??
I go to Excelsior Motorsports in Escondido. Tuners name is Kushan and he uses a Dynolog dynomometer.
Before this swap I did the 1/8th in 7.8ET @ 88.5mph with a 1.80 60'.
I know the exhaust is whats killing me now. Darn California But Im waiting for Pfadt's C5 LT's to come out this summer. I want to see how they do.
Ron, I love smoking beamers. The drivers are so smug it seems. They never admit defeat even when loosing. It had to be something else. 8.21... that was a while ago!
The track is basically a parking lot converted to a strip. But once in awhile they lay down some prepping stuff. Not sure what its called.
I know the suspension is more for the launch and ET. But I was more or less thinking I should see what difference the suspension makes on a different day. If i just go down and run both it and the new engine package, I wont know what the suspension actually did for improvement.
track prep stuff, called VHT is what they use maybe once every 3 or 4 months and only use it on the left lanes. exhaust could be hurting you mainly with not having long tubes. You really gotta trying going to Barona one saturday and seeing the difference your car will do there. having a auto car on a great track will get you good times, us 6 speed guys gotta work at it on the launch.
Thats what I hear. But Im usually busy saturdays. And its quite a drive from Oside with the drag pack and everything. When I get done at Qualcomm I just take my pick of several chick's places and crash there
But I should go see what its about one of these days. Are the time classes similar?
yeah theres grudge racing and what not. there are alot of test and tune cars. You might not get a lot of runs but the ones you do are quality. nice advantage having a chick to crash on lol
Nuke -- what's your tune? Has it been dyno-tuned with a/f set?
I ask because good heads and an emissions cam close-ish to Hot Cam would seem to put down more in my head - corrected dyno or no. +80 hp over the baseline is progress, but I wager there is room to grow in the tune.
My 100% stock longblock LS1 with headers, full exhaust, vortex rammer, bridge and coupler... (i.e. - just pipes and cai, really) put down 343rwhp and I forget the torque, but in the same ballpark give or take 10. That was on an awd dyno where my friend (tuner/operator) said I really ought to add 8% to that number and call it 371... which is a number I take a HUGE pinch of salt even considering sharing, because that number would surprise me. But then, my clutch has been slipping over 4500 since then so my SOTP meter is skewed low for the time being.
I'm sorry but this just isn't true, if it's uncorrected the results can swing wildly from day to day due to atmsopheric conditions. You can make changes to the vehicle that in all honesty would make power gains, but due to the conditions could show you a loss. So How would you ever be able to realiably determine that you are making improvements. It is important to use the same dyno and run the same correction standard each time. The corection factor is supposed to show you what the numbers would be as if you ran the car at the same atmospheric conditions each time. Yes there is a margin of error. But it is more important to use the same dyno, and same correction standard after each change done to the car. This gives you a much more accurate and reliable way of determining that the changes you are making are in the direction you want.
You make a good point. I did have the car dynoed last in December on a nice cool morning. This tune was the day after the hottest day of the year. I know temp is not the only factor. But Im pretty sure if all things were equal, I would have shown even higher numbers. The fact that I just tuned under less than ideal conditions gives me a pretty good feeling that the car is not showing any "higher than they should be" numbers.
But I do agree, for mod to mod power gains, a corrected dyno is best. However, I like to know what I am at right now and what I will be racing at this time of year. I prefer an uncorrected dyno.
