Back from the Dyno
Old Jul 3, 2013 | 03:40 PM
NukeC5's Avatar
NukeC5
Default Back from the Dyno
Just got done with the H/C swap and tuning. Though Id share the results. Before the swap, I was at 304whp/291wtq.
Cam installed was a custom grind 220/228 .578/.586 on a 115*LSA. Heads are fully ported 243's by WCC, w/ stainless steel valves and decked to 63cc.
Final readout was 387whp/337wtq. The cam was not exactly what I wanted, but I am impressed with a 83whp increase and 46wtq to say the least. I wanted a 222 or 224 int. and 114 LSA. But the specs are very close and I will have no trouble passing the sniffer here in Cali.
Still have yet to do long-tubes. So easily a 400whp car if I go that route.
Old Jul 3, 2013 | 03:48 PM
PRE-Z06's Avatar
PRE-Z06
Congrats, auto and stock stall?
Old Jul 3, 2013 | 05:02 PM
NukeC5's Avatar
NukeC5
Auto with 3.42 gears and a 3200 stall. That soaked up some of the numbers I know.
(RPM stage two diff, Yank billet SS3200)
Old Jul 3, 2013 | 06:02 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Great numbers and LT's to go. I am in the process on mine, RHS heads, 224 on 114LSA, LT's, and LS6 intake on my 2000 coupe 6 speed. Hope to get as good a results as yours.
Old Jul 3, 2013 | 06:12 PM
Rx7Rob's Avatar
Rx7Rob
I'd expect the headers to help alot! What intake manifold are you using?
Old Jul 3, 2013 | 06:24 PM
NukeC5's Avatar
NukeC5
Yes.. I suppose it is important to mention that I had my FAST92 port matched to the ported heads , And I already did my port match of the LS2 TB to the FAST before all this..
Other things to mention may be the ATI damper, BBK shorties, CHE rockers, titanium retainers and locks, x-pipe and axle back straight pipes.
Im itching to do the LT's now. I want to break 400 on this un-corrected dyno, and despite the gears and stall. A true 400 making it to the ground in addition to all the other goodies working together makes for a very fun car.
Old Jul 3, 2013 | 06:45 PM
chassed's Avatar
chassed
Very good results.
Throw some long tubes in there.
zeevette's Avatar
zeevette
I know it's an AT, but your numbers are really low for a H/C/I car. The addition of LTs to your shorties should be a pretty small gain. Your cam selection is conservative, but OK, so I'd guess the heads are to blame. Couldn't tell you how, especially since they're 243s, but stock (headers only) LS6s can beat those numbers, with stock heads, and the smaller LS6 cam.
Old Jul 3, 2013 | 06:51 PM
PRE-Z06's Avatar
PRE-Z06
He is a stalled auto...
OP if you're just wanting an uncorrected 400rwhp dyno sheet, just wait for a cold day and redyno
Old Jul 3, 2013 | 07:00 PM
chassed's Avatar
chassed
LoL SMH....
Old Jul 3, 2013 | 07:10 PM
NukeC5's Avatar
NukeC5
Thats odd that you would say that.. Its a very mild cam putting power through an auto trans with 3.42's and a 3200 stall on an uncorrected dyno in southern cali, in the summer, and w/o LT headers. Most people do not know what I mean when I say uncorrected dyno. My readings are around 10% less than what Id get on a DynoJet and the like.
This heads and mild cam package made 83 whp. Thats actually quite impressive... This goes to show why I hate the numbers game from DynoJets and the like. I dont want to get into this again. But right now I can take my car over to Cunningham motorsports nearby and dyno out 430ish whp if I wanted to.
Old Jul 3, 2013 | 07:17 PM
NukeC5's Avatar
NukeC5
Thanks, I know I can get better results, but my time slips are what Im actually looking forward to. I would rather dyno on less than ideal conditions to know that my car will perform this well or better at all times. Not good at one time and less the rest of the time.
I know you know what Im talking about. You seem like a pretty smart guy from posts in any threads I've read of yours
Old Jul 3, 2013 | 08:43 PM
RonSSNova's Avatar
RonSSNova
So, Drag strip this weekend then?
The hp increase ought to be good for about 8 mph in the 1/8 mile. My guess.
Ron
Old Jul 4, 2013 | 12:11 AM
NukeC5's Avatar
NukeC5
Ron
I have to wait till the 26th for the next race. 8-10mph is what my tuner thought as well. 7.2ish ET is his guess too.
Im waiting on a drag suspension kit from Pfadt, so hopefully it will come while I wait so I can race with a set of drag specific coilovers, poly control arm bushings, and the heavy rate rear bar.
Old Jul 4, 2013 | 01:09 AM
RonSSNova's Avatar
RonSSNova
Hope for good track prep.
Old Jul 4, 2013 | 02:29 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
uncorrected dyno? your numbers are not anything to post about .... sorry
Old Jul 4, 2013 | 09:07 AM
vettenuts's Avatar
vettenuts
Congrats. I think with the 3.42's and stall your numbers are very good. Curious how the idle is, do you think the sniffer guys will pick up on it?
To Back from the Dyno
Old Jul 4, 2013 | 09:09 AM
NukeC5's Avatar
NukeC5
Oh, your right. I never should have posted anything. The cam swap was obviously a complete failure. Maybe I will have a car as great as yours someday. But I'll bet that's just not possible.
Old Jul 4, 2013 | 09:15 AM
NukeC5's Avatar
NukeC5
Thanks,
The car got a bit louder, but on the 115LSA the idle is not really choppy. More of a fast pased "thump thump" but continuous without break. Both the LSA and the int. duration are very conservative to insure it passes. I have seen 224 and 114 cams pass here. But went down a few to make sure.
Old Jul 4, 2013 | 10:38 AM
chassed's Avatar
chassed
LOL tuff crowd!
