School me..Hurst Shifter
Old Jul 7, 2013 | 09:14 PM
Shane1974's Avatar
Shane1974
Default School me..Hurst Shifter
Z06
New to me.
Very direct and solid shifts.
The effort required to go between gears seems quite excessive. It is to the point that it would slow down shifts considerably over the stock slush box.
The shifter was already in the car I just bought.
What gives? Is there some adjustment?
Also, this is not my first vette with a shifter and mods.
A shifter is not designed to make it shift slower than stock, just more deliberate. I honestly do not know why someone would have this shifter in the car over the stock one for racing with its current setup. It is THAT HARD to change gears with.
I should not have to work to get the car in gear.
It is not about how manly you are or other. My Hurst shifter should not make the car worse.
Old Jul 7, 2013 | 09:47 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Same here,
I purchased my car with a HURST already installed. The shifter itself its crazy short but,
its very notchy to get into gears.
After the anti venom mod with two washers its was easier to move around. The bad about that was after the antivenom mod the shifter was too sloppy. By that i mean it wouldn't return to the neutral position so easily and just didn't feel right rowing through gears.
Long story short, took out the Hurst, replaced it with an MGW. All smiles here
Hope it helps
Old Jul 7, 2013 | 09:49 PM
Shane1974's Avatar
Shane1974
Originally Posted by Maxx_Z06
Same here,
Hope it helps
Thanks. I'll take that into account. I may be joining you. I will go maybe a week with this shifter the way it is and then stock is back in for a bit.
Old Jul 7, 2013 | 09:56 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Yea man there's a few people around who swear by the Hurst or B&M,MGW,C6 etc. It's all based on personal preference.
If you decide to take it out throw it on the for sale section, somebody will pick it up. That's what i did.
Old Jul 7, 2013 | 09:59 PM
bumble-z's Avatar
bumble-z
Shane1974,
Here are a couple articles in regards to the Hurst shifter.
Hope it helps.
http://www.hurst-shifters.com/wp-con...ds/3915085.pdf
http://www.corvetteactioncenter.com/...while-car.html
http://www.corvetteforum.net/c5/patc...rInstall.shtml .....Edit: Corrected
Old Jul 7, 2013 | 10:04 PM
Shane1974's Avatar
Shane1974
Originally Posted by bumble-z
Shane1974,
Hope it helps.
corvetteforum.net/c5/patches/Images/Hurst_Shifter/HurstSHifterInstall.shtml
Thanks much
Old Jul 8, 2013 | 11:20 AM
StatmanRN's Avatar
StatmanRN
One washer worked well for me.
Old Jul 8, 2013 | 11:28 AM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
I also bought mine with the hurst already installed. I have not driven a C5 with a stock shifter but, after test driving a C6 Z06 the other day and feeling a stock shifter for the first time I may change it back. The guy I bought the car from gave me all of the stock parts he had changed out including the shifter.
Old Jul 8, 2013 | 12:17 PM
vettenuts's Avatar
vettenuts
I bought the Hurst when it first came out. It was noisy and tiring to drive. I did one small trip with it and it came out shortly after that. I went with the C6 shifter, which at the time was the new kid on the block. It has been nothing short of perfect for me. It is smooth and shorter shifting than the original C5 stock shifter.
I may be a heretic, but I think the Hurst sucks and it ruined the whole driving experience in the car
Old Jul 8, 2013 | 02:46 PM
bmfvette's Avatar
bmfvette
I would try the "anti venom mod" (or check to see if it has been done) before I ripped it out.
To School me..Hurst Shifter
