Interior button lights
Old Jul 10, 2013 | 10:49 AM
Pres712's Avatar
Pres712
Default Interior button lights
Driving home last night with the lights on I noticed that the two top buttons on the selector panel were not lit. You know, the buttons to the right of the speedometer that say: Fuel, Gages, Trip, etc? The bottom 4 were lit but Fuel and Gages were out. Any ideas?
Old Jul 10, 2013 | 11:55 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I'm not sure where to get the bulbs, but here is a procedure to remove the dash cluster to get at the bulbs to replace them.
I replaced every bulb in my interior with White LED's.
http://www.spdkilz.com/techtipleddic.html
Toque
Old Jul 10, 2013 | 12:04 PM
Toque's Avatar
Toque
Forum Member "TSTAR" may have more information on this.
I think they are called "neo-wedge lamps"
See this thread too....
http://forums.corvetteforum.com/c5-g...od-thread.html
Toque
Old Jul 10, 2013 | 12:10 PM
Toque's Avatar
Toque
Found some stuff...
Originally Posted by PhilsFRC
Number 32 and 33 here:
http://parts.nalleygmc.com/showAssem...rimLevel=14233
Need 1 #32 and 3 #33.
Originally Posted by tstar
Here's a good source for the bulbs;
http://www.mcmaster.com/#1505k414/=3tnuwi
And instructions to get access to the switch pack;
http://www.vetteessentials.com/instr...zel_howto.html
Originally Posted by ICUALL
Same as in the door switches, I used these and just replaced the bulb itself .
http://www.topbulb.com/find/Product_...ductID_E_42901
These will work also
http://www.radioshack.com/product/in...tId=2104023&cp
Old Jul 11, 2013 | 07:05 AM
Pres712's Avatar
Pres712
Originally Posted by Toque
Found some stuff...
It looks like I've got to take almost the entire dash apart to get the gage assembly off to get to the back of these buttons? Just to replace two bulbs? I would think you could just pop off the button and the bulb would be exposed?
Old Jul 11, 2013 | 08:11 AM
Toque's Avatar
Toque
Yes,,,, its a pain to get to the back of the buttons.
Toque
Old Jul 11, 2013 | 12:10 PM
dadaroo's Avatar
dadaroo
One bulb serves 2 buttons. Contact TSTAR for a replacement bulb.
Old Jul 12, 2013 | 07:47 AM
Pres712's Avatar
Pres712
If I have to take apart the entire instrument assembly to just replace a bulb...forget it!!! One of these days I have to fix the temp display and will look at it then. Thanks for all your help!!
To Interior button lights
