Actuator for Left Headlight door
Old Jul 11, 2013 | 11:47 AM
agonzo48's Avatar
agonzo48
5th Gear
Default Actuator for Left Headlight door
Just got a call from the Chevy dealer. It will cost me $390.00 plus $300.00 labor to replace the actuator motor for the left headlight blend door (think thats what its called - the thingy that goes up and down). The light itself is operating but it will not come up out of the body. Any suggestions. 2002 C5 convertible.
Old Jul 11, 2013 | 11:49 AM
agonzo48's Avatar
agonzo48
5th Gear
Also read somewhere that there is a brass gear that can be replaced that someone got on Ebay for 12.95. $690.00 get the headlight door open? Thats 1.38% of what I paid for the Vette.
Old Jul 11, 2013 | 11:52 AM
jamieo's Avatar
jamieo
You can get an aftermarket one for less than $200 and change it yourself in less than an hour.That is why they are called "stealerships'!!Does the motor run but the headlight won't move?If so,the gear will fix it for way less money!!
Old Jul 11, 2013 | 12:25 PM
lionelhutz's Avatar
lionelhutz
A new gear would likely fix it. The metal ones are more like $40. You have to break the motor case open, replace the gear and then glue it back together. I believe the one gear supplier provides a bracket that helps to hold it together after you are done. Not too difficult, but it's a do it yourself type of fix that most repair shops likely wouldn't touch.
Old Jul 11, 2013 | 12:28 PM
woodvette03's Avatar
woodvette03
$690 is a total rip off.
if the motor sounds like it is grinding, it is the gear inside that you can replace yourself in about 2 hours or less. i got a plastic gear at the local parts store for $6 but the brass ones are better if you can get one. i am sure you can find a post on here on how to do it.
Old Jul 14, 2013 | 01:34 AM
C5INBLU's Avatar
C5INBLU
Five years ago I installed new brass gears in both headlamp actuator assemblies. ( http://rodneydickman.com/catalog/pro...products_id=92 ). This page also has links to installation guides, including one here on the forum. All was well until recently when the left hand lift operation again became erratic. Exploration revealed that the plastic gear housing had badly cracked where the metal motor housing was attached to it. The result was that the worm gear attached to the motor shaft was only making intermittent contact with the large brass gear inside the gear housing. I ordered a brand new AC-Delco actuator assembly from RockAuto.com for $188.79 installed it myself (3rd time is a breeze). Now everything works again.
Old Jul 14, 2013 | 10:13 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
its a DIY job....
Old Jul 14, 2013 | 04:01 PM
magneticred's Avatar
magneticred
DIY:
http://forums.corvetteforum.com/c5-g...orialized.html
This guy even fixed his Firebird by reusing the good half of the old gear:
http://www.freewebs.com/headlight/headlightmotorfix.htm
Old Jul 14, 2013 | 04:57 PM
lionelhutz's Avatar
lionelhutz
If you want to test it or just be cheap then take the arm off the motor and rotate it 1/2 turn and put the arm back on. That will move the end stops to a different spot on the gear and it'll likely start to work fine again.
To Actuator for Left Headlight door
