Transmission/engine problems and help
Old Jul 15, 2013 | 05:26 PM
etm34's Avatar
etm34
1st Gear
Default Transmission/engine problems and help
So we have a 2003 corvette c5 with 32xxx miles on it, automatic. it isnt driven hard but once in awhile for a few minutes, we are the second owners, however, but the first owners were an older couple. Ok enough backstory..
Problem:
1.When accelerating hard from around 0-10mph gear up to around 45+mph, the car accelerates fine and then all of a sudden when switching into 2nd the gear doesnt engage properly, atleast i think, still accelerates, but it isnt the same type of acceleration, rpms seem too high for the speed and reved up to quick, but after letting off the gas the car engine light comes on, car sputters and gear is no longer engaged, put in neutral and engine stalls and have to pull to side of road, turn of car, restart and runs fine.
2. Accelerating out of corner hard, let off gas, go to stop sign and turn and gear wont fully engage and engine sputters and car lurches forward halway engaging gear giving it enough momentum to get up to around 5mph. engine stalls, wont start up, after a minute of not trying it starts back up and runs fine.
3. Highway fun.... acclerating hard from 70moh up to 100mph, you can get to 90mph and then the car wont engage 4th gear and overevs and tries to engage the gear, have to let off gas temporarily and go back one to engage 4th gear.
So now to the questions, is this a computer problem with the timing and gear changes or is this a transmission problem and the transmission needs to be replaced? Any help would much be appreciated. s
Old Jul 15, 2013 | 05:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Read and post the DTCs Other wise, it VERY difficult to help
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
