Which header?
Old Jul 16, 2013 | 08:09 AM
zeke2u's Avatar
zeke2u
Default Which header?
Can't decide which brand to choose: LG or ARH. Would also consider Pfadt if they made them for the LS6/Z06.
The LG's, from the pictures I've seen, look like they have less bending/curves and would flow smoother/better. I'd probably use the 'Street' series, w/cats. Does anyone have experience with both brands and if you do, could you give the pro's and con's of each? Is one harder than the other, in terms of installation?
Old Jul 16, 2013 | 08:27 AM
zeke2u's Avatar
zeke2u
Oops...Pfadt does make the Tri-Y for the LS6. Still would like to hear the comparisons between the LG's and ARH's....
Old Jul 16, 2013 | 09:11 AM
feeder82's Avatar
feeder82
I have ARH they fit great, easy to install, great CS if you have questions.
Old Jul 16, 2013 | 10:02 AM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
Surprised more people don't mention the TSP stuff. Stainless steel, 1/3 the price, and very nice fitment. Of course, them keeping them in stock is another story.
Old Jul 16, 2013 | 10:21 AM
95rtturbo's Avatar
95rtturbo
Can't go wrong either way - both make quality headers.
Old Jul 16, 2013 | 10:33 AM
NukeC5's Avatar
NukeC5
Im waiting for Pfadt's C5 headers to hit the market at the end of the summer. If they are still on schedule that is..
Old Jul 16, 2013 | 12:21 PM
hamhead's Avatar
hamhead
For what its worth, I went with these and had no problems.
But if the OP is dead set on the two, you really can't go wrong either way. I have heard that ARH is the easier install - most shops charge less for the ARH install.
Old Jul 16, 2013 | 02:12 PM
zeke2u's Avatar
zeke2u
feeder82 - Did you install them? If so, how long did it take and what did you have to remove to fit them?
NukeC5 - Will the Pfadts allow use of the stock H-pipe, like on the C6's?
Old Jul 16, 2013 | 02:24 PM
RonSSNova's Avatar
RonSSNova
With the exception of shorties, all the aftermarket headers use an X pipe setup.
Also, between the various 4-1 headers, there probably isn't going to be a huge difference in the power or torque curves. I don't recall any direct comparrisons of the various manufacturers offering on the same car.....that would take forever to do and a lot of $$$.
I believe the Phadt Try-Y is going to stand out in the HP/TQ department.
Ron
Old Jul 16, 2013 | 03:07 PM
zeke2u's Avatar
zeke2u
Ron - If I'm not mistaken, the TS&P is a long-tube and allows the use of the stock H-pipe. After cutting the flange on the stock H-pipe, they're joined together with SS band-clamps. Also, I believe (IIRC) the Pfadt Tri-Y, for the C6, will actually bolt right up to the stock H-pipe. I haven't seen any pictures of the Pfadt for the C5's - I'm hoping that it, too, can be bolted to the stock H-pipe. Although, I've been a fan of those Random Technology cat's since my Saab turbo days. The Phadts look like they're also going to stand-out in the weld quality - they're unbelievable, a work of art, almost.
Old Jul 16, 2013 | 03:18 PM
vettenuts's Avatar
vettenuts
I have run both Tri-Y (QTP) and 4 to 1 and done dyno's on both. My opinion is wait for the Pfadt Tri-Y's if you are buying new. GM stock manifolds are a Tri-Y design, I think because GM knew something
Old Jul 16, 2013 | 03:34 PM
C5_phillouieambers's Avatar
C5_phillouieambers
5th Gear
I called Pfadt yesterday and they said that they are currently in the process of building c5 headers. Now that the Camaro line is done, the c5 has their full attention, they said a few weeks and they will offer a pre-sale
Old Jul 16, 2013 | 03:43 PM
zeke2u's Avatar
zeke2u
That's good news - I was wrong above: it's the Pfadt Tri-Y for the Camaro that allows "Direct connection to factory X-Pipe and after market Cat-backs". The C5 will probably need the X-pipe, like the C6.
Old Jul 16, 2013 | 04:20 PM
Smooth's Avatar
Smooth
I'm looking too for sometime in the near future. probably a winter project. And since its a my garage install, the 2 things on the "Most important" list are 1. Is it going to improve performance( at least somewhat, not just add noise) and 2. ease of install as mentioned above. The ARHs were said above to be easier and if shops generally charge less to install, that says something. What does actually need to come off? Just the starter?
Thanks Guys!
Old Jul 16, 2013 | 04:27 PM
hamhead's Avatar
hamhead
Thanks Guys!
I didn't do ARH, but at least for me with TSP, I had to (at least from memory):
Driver's side:
Alternator
Ground strap
Coils/plugs/plug wires/valve cover
Your nemesis on the driver's side is the steering shaft. I wiggled mine on without disconnecting.
Passenger's side:
Oil dipstick
coils/plugs/plug wires/valve cover
starter
For me, I probably could have gotten away with not removing some (starter for instance) but in most cases I'd rather just take ten minutes to remove something rather than spend ten minutes heaving and prying to get something to fit around it.
Old Jul 16, 2013 | 05:44 PM
Rx7Rob's Avatar
Rx7Rob
With the ARH's I had to fab a new dipstick bracket. I don't know if any of the other brands includes it with the headers.
Old Jul 16, 2013 | 06:26 PM
zeke2u's Avatar
zeke2u
Yes, thanks hamhead and Rx7Rob.
Smooth - As I'll be installing my own, also, ease of installation is high on the priority list. From what I've read, the LG's seem to require both the starter and alternator removal. I haven't heard about what requires removal with the ARH's. However, Pfadts are promoting their headers on their design, as well as the performance. From what I've read about the C6 versions, they bolt right up without removing much except for the stock manifolds. It's beginning to look like I'll delay the purchase a few weeks until the Pfadts are offered - unless someone can add to the discussion and convince me to go a different route.
To Which header?
Old Jul 16, 2013 | 07:02 PM
Bluefire's Avatar
Bluefire
I installed ARH on my '03 Coupe. It was "easy as pie".
I am certain ARH are made with American steel too.
Old Jul 16, 2013 | 07:27 PM
zeke2u's Avatar
zeke2u
Thanks Bluefire, but could you expand on "easy as pie"? Did either the alternator or starter have to be removed? Did you have access to a lift? Etc.
Old Jul 16, 2013 | 08:49 PM
momo20's Avatar
momo20
I went with the Lg street setup ..I thought there were pretty easy to install...the only think I don't like is the clamps they send..for what you pay for the set they could include a better exhaust clamp...but aside from that I love my setup
