Vats???
Old Jul 27, 2013 | 06:32 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Vats???
Reading threads on ignition switch and people refer to "VATS"...what might this be??
thanks
Old Jul 27, 2013 | 06:35 PM
momo20's Avatar
momo20
thanks
vehicle anti theft system
Old Jul 27, 2013 | 06:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The metal Can (Sensor) on the end of your ignition cylinder is the sensor that reads the resistor embedded in your key.
The resistance of that chip MUST match the resistance value that is programmed in the BCM.
If they do not match, the SECURITY light on the IPC will flash and you will NOT be able to start the engine.
If you try, it will lock out the start enable for 3 minutes.
BC
To Vats???
