Fule pump rele
Karl bought a car that was flooded in Hurricane Sandy. He has done some electrical work and is having a problem with the fuel pump relay. Sometimes when he turns the key on, the fuel pump relay starts ticking, the fuel gage show empty, and the temp gage goes to max. When this happens he has “no communication with the PCM.” (I’m assuming he is pulling the codes) Other times he can start the car and everything is normal.
I’m guessing he might have an ignition switch problem.
Karl – List the codes you are getting and it will help people diagnose your problem.
Hope this helps
I have a BIG HEART when people in other countries attempt to work on cars that are this USA COMPLEX!
I will do what I can to assist you with your C5 issues.
The very first place that i would start would be the IGNITION SWITCH.
Here is a post that will allow you to repair your switch. Before you DIG INTO SWITCH REPAIR,,,, use a DC VOLT METER and measure the voltage on the fuel pump fuse to chassis ground. There are TWO TEST POINTS on top of each fuse. Measure eash test point to ground. You should see FULL BATTERY VOLTAGE when the ignition switch is ON.
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
If it reads normal, read the test points again when the relay is having it issues. I believe that you are at times UNDER VOLTAGE because the contacts inside the ignition switch are burnt and pitted.
The GROUND for the fuel pump and fuel gage is G-401. It is in the drivers side rear wheel well on the side of the frame. Its a stud with a 10mm nut. Carefully remove it and make sure that the frame and eyelet are clean and tight.
Please let us know how your troubleshooting efforts work out:
Here is an early fuel pump schematic but it shows power and ground:
Hope this helps
Bill
I have full bateri volt fuse to the fuel pump 12'5 volts. 'll check on the key switch and it is new've checked all ground connections and clean them and some I have changed all the modules I have changed and all the contacts are clean and changed. brublemt the relay is that when I turned on igniskon start the relay to tick all the time and I have troubleshoot some time until I came to tac module when I removed the power plug to the module when the relay works as it should rotate ing starts the fuel pump and works in 3 sec and they are as they should be. and have checked all the wiring harnesses and clean them. my question is now Bill C if you can start the car without tac module. I will post utt some pictures of my Projeckt flloodet corvette c5 50th thanks again to Bill C and I raporterar how it goes
corvette starts and works and no error codes on the pcm
I have replace tac module and the gas pedal and they work very well
problem is the fuel system. I think I have an internal lekage., I have changed the fuel pump and then I had 50-60psi and now I have only 3 psi so I have to take down the fuel tank again they are not funny at all
then I connected an external fuel pump and when the engine works very well now remains pro code programming with tech2 will surely hear from me more
