Will LS7 lifters hold up
Old Aug 2, 2013 | 10:44 PM
mobman's Avatar
mobman
Default Will LS7 lifters hold up
Will LS7 lifters hold up on a .630 lift cam or is there a better option?
Old Aug 3, 2013 | 12:36 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I would do some search and asking questions over on the LS1Tech Forums
http://ls1tech.com/forums/welcome-ls1tech-82/
Old Aug 3, 2013 | 07:35 AM
vettenuts's Avatar
vettenuts
One of the design parameters of the Morel lifters was the ability to handle higher lift without oiling issues. I would personally look at Morel lifters for this application. There are many of other improvements as well, this is just one.
Old Aug 3, 2013 | 07:40 AM
helga203's Avatar
helga203
Just a thought ls 7 are in the Z06 that rev to 7500rpm with cam lifts in the mid .650ish. just a thought.
Old Aug 3, 2013 | 05:34 PM
mobman's Avatar
mobman
I wouldn't be reving mine above 6500. I don't race it so maybe this is the way to go. I would hate to spend allot extra for the morels if the LS7 lifters would a reliable option.
Old Aug 3, 2013 | 05:46 PM
Skypilot797's Avatar
Skypilot797
Been running LS 7 lifters on more than .651 intake/.661 exhaust, shifting at 7,000 rpm, no problems. I do have a melling high pressure oil pump.
Best to call a speed shop and ask them. Most vendors are aware of these questions and are reliable for the best answers.
Old Aug 4, 2013 | 09:13 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I run the Caddy Racing lifters with a 610 lift and run pretty hard to 6850 rpm. ZERO issues (knock on wood) I also have the melling high pressure pump.
My buddy warlock007 switched to a set of linked lifters and is very happy with them. I forget who makes them.
Bill
Old Aug 4, 2013 | 10:50 AM
CTD's Avatar
CTD
I'm .647/.654 & not skeered to run 7200 rpm. Knock on wood also
Old Aug 4, 2013 | 11:14 AM
00Vette04GTO's Avatar
00Vette04GTO
My LS7 lifters did not make it but about 100 miles - but believe it is just a mix of a moronic engine builder and a factory defect.
I am upgrading to Lunati lifters just to be sure. They have the crossbar between them (linked lifters as said above). They are $375 at Summit.
To Will LS7 lifters hold up
