Pretty sure I know what lies ahead, but I'll put it out there anyway.
Just started happening, maybe 15 mins of total run time since I noticed it. Above the usual valvetrain clatter a squeaky almost scraping sound emerged. Sometimes it's there, sometimes not. Doesn't really change with RPMs
Narrowed it to driver's side. Pulled VC and inspected Pushrods and rockers. All look fine. Plugs are nicely colored. Think I'm looking at lifter with maybe a bad roller or maybe clocked? Not sure due to the frequency not changing with revs.
Not looking forward to tearing it down.
Vid:
Reason: Resolved
Checked your crank pulley? See if it's moved back against the timing cover?
Have an SLP Balancer/Underdrive pulley. It's fine, belts are good
Originally Posted by mchicia1
Before you do anything, take off both belts and run the car.
Noises in these cars travel very far. The noise sounds external to me.
My first thought was a tensioner or bearing, but it seems to come from the top. Used my stethescope, but it doesn't nail down a location, so I'll run sans belts tomorrow.
I sure hope that's it!
Originally Posted by vettenuts
I am not thinking lifter either. That almost sounds like air leak or something. I would check things out real well before going into the motor.
How is the AIR system, are the rubber hoses OK?
Thought vacuum or exhaust too, but all is tight. I'll look at AIR too, and spray some carb cleaner around intake/head surface.
I had a similar noise and thought it was a lifter too. I took my best stethoscope to it and it turned out to be coming from the fuel injector.
After a tank or two of injector cleaner and 10000 miles later it got much quieter, but never went away.
Have you tried running most of a can of Seafoam through your gas tank? That stuff is magic.
Pull the valve cover and examine the rockers , springs and pushrods.
C5 rockers are WELL KNOWN to PUKE out all the little needle bearings inside the rocker and it can make that noise.
IF,,,, that is the issue, recommend that you do the TRUNION UPGRADE and replace all the rocker trunions.
When you find the root cause,, take plenty of pictures!!!:cheers :
Bill
I did remove and inspect all the rockers and pushrods, all fine. Springs are upgraded and all look great. Squealing is getting louder, still located around #5 intake. Sounds like a lifter roller is bad or maybe rotated and scraping on the cam. If that's the case, time for linked lifters and maybe a little more cam. Don't have the time or space to tear it apart (remodeling kitchen and 2 bathrooms), so it's going in to the shop tomorrow.
I'll post the results.
Link-bar lifters are good, but expensive. Using new lifter cups is VERY important when using LS7 or CTSV lifters. Thousands of engines out there just fine with them.
If you DO decide on links, I'd really recommend Morels.
Unfortunately, I too had the same/similar valvetrain noise occur to my H/C engine. Progressively became worse. Removed Crane 1.8 rockers and replaced with original stock rockers (with trunion modification) with no improvement. Simply became worse. Towing resulted to avoid additional damage. Teardown revealed cam lobes completely trenched out apparently due to improper heat treatment of the Crane cam. One lifter had slightly turned as a result thus a scraping sound. (FYI, aftermarket springs were correct rates thus not suspect of contibuting to failure.)
This may be your problem or hopefully a failing lifter. My final install included retaining stock rockers, LS7 lifters and a different cam manufacturer with a different profile. Did cost money, but excellent performance gain with new cam was worth it. Best of luck...
How long had you been running that cam? Did Crane help out at all?
About eighteen months if I recall. Did not contact Crane or VHP regarding cam lobe failure. Considered their business issues at the time and decided it best to move on to another manufacturer. Issues like this do happen from time to time. I suspect they would have replaced the cam accordingly...
A1
I had a problem with a Crane cam myself and it required a rebuild of my Morel lifters because the rollers were starting to get grooves in them. I was removing for another cam swap anyhow and found this in the process. I shipped both cam and lifters to Morel for diagnosis and found the cam to be at fault. Lifters are now running on an AFR 6016 (Comp) cam.
