need some direction from diff/trans experts
Old Aug 9, 2013 | 04:06 PM
seansz28's Avatar
seansz28
Default need some direction from diff/trans experts
got the diff removed. the front of the diff blew off and sheered a shaft right in half. this shaft in question is in the pic . is this a pinion shaft or the t56 output shaft because im not familiar with these components. and where do i find a replacment? thanks for the help!!
Old Aug 9, 2013 | 04:12 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
That's the output shaft from the transmission.
Gotta take the Trans apart to fix. They make a hardened version, as well as a 30 spline piece.
I put the 30 spline in my Trans when I had it built. The pinion needs to be machined to accept the 30 spline shaft. About $250 if I remember correctly.
Good luck with your repairs.
Old Aug 9, 2013 | 04:13 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Stock is 27 spline.
Old Aug 9, 2013 | 04:25 PM
seansz28's Avatar
seansz28
where would i find a new output shaft?
Old Aug 9, 2013 | 06:33 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Good question. I just had the shop that built my Trans source the parts.
There are several vendors on here that build transmissions. Perhaps they'll chime in here.
Old Aug 9, 2013 | 08:16 PM
RedZMonte's Avatar
RedZMonte
search for "C5 Hardend output shaft" you will see a few vendors here sell them... just dont google image that search... might see some "Junk" jk
Old Aug 9, 2013 | 09:26 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Sean, where you from?
To need some direction from diff/trans experts
