Service Active Handling message, no codes
Old Aug 9, 2013 | 11:06 PM
nascar57's Avatar
nascar57
Default Service Active Handling message, no codes
I'm on a long trip and started getting Service active handling , service vehicle soon message. Hooked up the Predator and there were no codes stored. Happened 5 or 6 times. A couple times when I dropped below 55mph, it felt like one of the brakes was applying themselves for a second and the active handling message would come up then go away. This happened a couple times. My brother once had similar issues and it ended up being a steering wheel position sensor but he had a code set. Oh, also the cruise has been kicking off also. Any ideas? Really confused as to why no codes were set.
Old Aug 10, 2013 | 12:14 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Quote"
That was you're first mistake..
I agree with 8vette7.. Use the internal DTC reading capability
Bill
Old Aug 10, 2013 | 08:43 AM
nascar57's Avatar
nascar57
Wow. Did not realize the predator would not pull all codes. I will use the cars system and see what it reads. Update later! Thank you for the info.
Old Aug 10, 2013 | 08:53 AM
coia96vette's Avatar
coia96vette
After you pull your codes from the dic, I bet you will get C1287 and or C1288. That would be the SWPS. I had the same thing happen to my 04. Changed out the sensor and no problems since.
Old Aug 10, 2013 | 11:44 PM
nascar57's Avatar
nascar57
Codes I found for the a/h system are 1221, 1222, 1218, 1287, 1288. I dont have the manuals with me. Will have to research them when I get back but more and more I'm thinking the swps is going to have to be replaced.
Old Aug 11, 2013 | 08:42 AM
nascar57's Avatar
nascar57
Sorry for the missing information. Trying to do this and juggle vacation activities too. I'm not going to be able to check the wheel speed sensors untill I return home later this week. I will check the codes again and be a little more attentive. I really appreciate your advice. thanks.
Old Aug 11, 2013 | 01:35 PM
nascar57's Avatar
nascar57
Just pulled the codes again and they are
C1221 H LF Wheel speed sensor input signal zero.
C1222 H RF wheel speed sensor input signal zero.
C1248 H ???
C1287 H Steering sensor rate malfunction
C1288 H Steering sensor issue related to C1287.
Not sure what the c1248 H is for.
Old Aug 15, 2013 | 10:27 PM
nascar57's Avatar
nascar57
O.K.. I started from scratch, erased all codes and put about 600 miles on the car. The service A/H, traction control message came on, kicked the cruise off. I checked the codes without shutting the engine off and got C1287 H C AND C1288 H C. Both of these are related to the swps I understand. The same thing happened twice on that run. Assuming I need to replace the swps to correct this issue. Best place to buy one?
Old Aug 15, 2013 | 11:52 PM
nascar57's Avatar
nascar57
Thank You for all your help. I certainly have learned allot on pulling codes. I'm wondering what the Predator is even useful for!! Its not even a good code reader.
To Service Active Handling message, no codes
