changing coolant
Old Aug 12, 2013 | 07:50 AM
dperrucc's Avatar
dperrucc
6th Gear
Default changing coolant
I own a 2000 vette ,4400 miles,should I change coolant(never changed)?
If change,what is best coolant?
thank you
Old Aug 12, 2013 | 11:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DEXCOOL or equivlent!! DO NOT use the green ethylene glycol OR propylene glycol!!!!!
You need Organic Acid Technology (OAT) which is a Long Life Coolant (LLC) / Extended Life Coolant (ELC) widely used in Europe before its introduction in North America. OAT is usually EG. The generally recommended replacement interval is five years or 150,000 miles.
DEXCOOL was TEXACO brand but there are other brands that use OAT formula that will work.
Old Aug 12, 2013 | 12:40 PM
Cybermind's Avatar
Cybermind
You can also get Dexcool under the Prestone brand. That's what I used.
To changing coolant
