I have a 99 vert. I have been taking all my custom parts off to sell. I removed my Pfadt Street Sway bar, and sold it. Now, I asked my 22 year old son to install the OEM sway bars. Unfortunately, he was using an impact wrench, and snapped off the bolt on the support bracket on the passenger side. Now, my sway bar rattles around. My son tried to drill it out, and use an easy-out to remove it, but just broke the easy-out in the broken bolt. I need to fix this, but a mechanic told me the bolt is broke off in the front cradle, and that cannot be repaired. He told me I need to replace the front cradle!
I need a better solution. Is there another after market sway bar that does not use these OEM brackets?
Does anyone have a different idea on how to fix what I have?
Thanks everyone. I did not know the bolt hole went all the way through the cradle. I will ask around for a shop that can fix this. I appreciate the help!
For some reason, I see a lot of cross threading issues with those bolts, not just in vettes, but Camaros and TAs also. Not sure if it is a steel bolt vs al cradle issue or what. Good luck with the repair.
