Powerbond Damper
Old Aug 18, 2013 | 04:16 PM
newbs49's Avatar
newbs49
Default Powerbond Damper
Trying to get some info. Is anyone running a Powebond 25% underdrive
damper. Looking to get a cam installed and installer is recomending this damper. Anyone have any info they can pass on. 01 Zo6
Old Aug 18, 2013 | 04:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its a MAINSTAY in replacement dampeners! Ive had mine for 6+ years and have had ZERO issues with it.
No over heating, No charging issues no nothing...
I pinned mine to the crank using a side pin kit
The ONLY thing that I would do different is, paint it before i installed it. Its steel and it will rust.
Im heavily modded and it works great.
BC
BC
Old Aug 18, 2013 | 05:37 PM
newbs49's Avatar
newbs49
Thanks Bill !!! much appreciated
Old Aug 18, 2013 | 06:28 PM
Last C5's Avatar
Last C5
BC
: Bill got it right! (As usual ) Mine is installed on an 01Z that's heavily modded and tracked regularly. No problems. SDPC has it in a kit with the two shorter belts you need and a new balancer bolt.
Old Aug 18, 2013 | 06:58 PM
newbs49's Avatar
newbs49
Thanks again for the info !!!!!
Old Aug 19, 2013 | 12:09 AM
Ohyoufan's Avatar
Ohyoufan
^This! I had a 25% Powerbond UD on my old WS6 and now my bolt-on FRC and I've never had any charging, steering, or voltage issues on either vehicle for the 20,000+ miles they were/are on. I used to live an hour from Lubbock and always drove to Scoggin Dickey or Texas Speed for parts. You'll find the best deal at Scoggin Dickey's.
Old Aug 19, 2013 | 11:58 AM
Mr. Jones's Avatar
Mr. Jones
I am running the Powebond 25% underdrive.
yes paint it. No problems here, I did pin mine.
I do run a smaller than stock alt. pulley but it's not needed.
Old Aug 19, 2013 | 12:41 PM
lionelhutz's Avatar
lionelhutz
The Powerbond is a good piece and you won't have issues with it failing. You really shouldn't have issues but a 25% under drive does remove any extra margin in the accessory drives. Your tuner will likely bump the idle a little bit which will help make up for the loss.
I do find that if I'm idling into a parking lot in 1st as I turn into a spot the turn can pull the rpm down and then the steering assist drops and the steering becomes heavy. I had the car slowly overheat in a bad traffic jamb at night. Very slowly. I was watching the voltage and it very slowly dropped and as it dropped the fans slow down and the temps climb. I eventually turned the AC off and it slowly recovered. I'm stock internally so there is no reason it should need a higher idle rpm.
Old Aug 19, 2013 | 01:02 PM
newbs49's Avatar
newbs49
Thanks everyone....good info
Old Aug 19, 2013 | 01:25 PM
lionelhutz's Avatar
lionelhutz
I should have posted the timing. It was about an hour before I had to turn the AC off. It was a very slow creep.
Old Aug 20, 2013 | 07:16 PM
SDPC's Avatar
0SDPC
Former Vendor
Thanks for the positive references guys. We appreciate your business and we are very happy to serve you. You can find the kit for a C5 here:
https://sdparts.com/details/powerbon...pbu1117ss25-c5
And if you post in the comments that Jesse sent you from the forum we will remove the shipping from your order when we process it!
Alternately, you could just call me. 800-456-0211 ext 358.
Old Aug 20, 2013 | 07:55 PM
LoneStarFRC's Avatar
LoneStarFRC
BC
: Bill got it right! (As usual ) Mine is installed on an 01Z that's heavily modded and tracked regularly. No problems..........
What they said.
Old Aug 21, 2013 | 12:05 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
I also have a PB 25% pulley for about 5 years no problems, agree with the other posters above it's a good piece.
Old Aug 27, 2013 | 11:51 PM
newbs49's Avatar
newbs49
what brand belts are you guys using?
Gatorback-Gates
To Powerbond Damper
