buy or build
Old Aug 23, 2013 | 06:31 PM
Blow Torch's Avatar
Blow Torch
Originally Posted by zeevette
I don't know anything about Schwanke, but if the price is close, go for the LS2. Your heads will bolt-on.
$1100 more PLUS the conversion kit
Not sure if 3 liters is worth $1300+
They been in busness for over 20 years, so I guess they do something right
Old Aug 26, 2013 | 10:15 AM
Blow Torch's Avatar
Blow Torch
Best price so far;
Alumium LS1 (new 5.3 block bored to spec) with wiseco pistons, arp2000 rod bolts and forged rods, stock, new crank.
Want it to handle around 800rwhp
Old Aug 26, 2013 | 12:48 PM
zeevette's Avatar
zeevette
With the right top end, that'll be a good budget boost motor, but if it doesn't have top internal components, I would be careful with the boost required to make your desired HP level.
Old Aug 26, 2013 | 01:31 PM
Blow Torch's Avatar
Blow Torch
The Dart heads are supposed to have a thick head/block surface to withstand boost or N2O without warping. I have Yella Terra rockers and custom length harden pushrods. Springs are the stock Dart springs that are supposed to be good to 625 lift
