wondering if i need/should replace the accumulator, since i will have the schrader valve out maybe all of 2-3 minutes at the most which will be exposed to outside air..??
My car was just there last week getting a Monster stg3 clutch done plus other things that needed fixin... Joe is good people
I dunno...if he can't he knows someone who can. he has a great AC machine he bought last year.
Change both valves dont bother evacuating unless you blos air into the system
Had a leaky one a couple years ago. Got new ones for about $1 apiece at AC supply. You are not completely opening up the system to pull 2 valves out. If you have a vacuum pump and want to kill an hour evacuating go for it but if you simply unscrew the valve stems and pop in new ones it is not necessary. Need a long valve stem tool you can find at a parts store or AC supply to get the cores out.
