a/c problem
Old Aug 28, 2013 | 02:35 PM
bpp70's Avatar
bpp70
Default a/c problem
a/c not cold tried to add some 134 but clutch not coming on won't take any 134 anyway of by passing switch to see if compressor clutch will power up?? seeing if compressor is bad or have wiring issues.Thanks
Old Aug 28, 2013 | 04:48 PM
BigGun's Avatar
BigGun
Is your outside temperature display correct. If it thinks its too cold the compressor won't come on. Did you check the pressure before you tried to add the 134? Usually the can will have enough pressure to start the compressor.
Old Aug 28, 2013 | 06:35 PM
bpp70's Avatar
bpp70
Ill check outside temp I think it's off it reads colder than it is outside like 62 and its 90 out. How do I fix that issue.
Old Aug 28, 2013 | 08:26 PM
bpp70's Avatar
bpp70
Just checked car reads outside temp of 65 all the time maybe this could be affecting a/c operation
Old Aug 28, 2013 | 08:30 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
thats the issue....unplug it and clean it if you have some electrical contact cleaner...
also if you unplug it and plug it back in it may not work still...try disconnecting battery for 10 minutes thats how I reset mine
if that doesn't do it you may need a new sensor
Old Aug 28, 2013 | 08:39 PM
bpp70's Avatar
bpp70
Ok thanks ill put new one in and try it.
Old Aug 28, 2013 | 08:41 PM
pewter99's Avatar
pewter99
try the battery disconnect first
Old Aug 28, 2013 | 08:43 PM
hornet7's Avatar
hornet7
Default Codes
Download and post your codes?
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
Old Aug 28, 2013 | 08:45 PM
pewter99's Avatar
pewter99
I didn't have codes when I had the issue...just a low reading from outside sensor....mine read 28 degrees...it was freaking 92
I unplugged it...plugged it back in....nada....disconnected battery...reconnect and
Old Aug 29, 2013 | 12:00 PM
BigGun's Avatar
BigGun
Be sure to take a good look at the wires and connecter. Sometimes the problem is corrosion inside the connecter.
Old Aug 29, 2013 | 01:37 PM
bpp70's Avatar
bpp70
Ok I will do that first thanks for the help.
Old Aug 29, 2013 | 04:54 PM
SaberD's Avatar
SaberD
the compressor should always come on when you put it on defrost regardless of temperature, because it is used to dehumidify the air.
Old Aug 29, 2013 | 09:10 PM
3sACROWD's Avatar
3sACROWD
Have you checked your fuses? As Pewter99 stated, the erroneous outside air temp reading may also be the culprit. Try what he suggested.
Someone recently had a problem with their AC after the engine was detailed. When they disconnected the outside air temp sensor the AC worked.
To a/c problem
