Overheating help
Old Sep 12, 2013 | 02:56 PM
silas1234's Avatar
silas1234
Default Overheating help
2003 z06 100k miles cold air intake everything else stock. I bought this from an insurance sale and I have no info on past use. I bought this to make a track car out of it. Car runs fine no issues no oil in the water and its not losing any water. If you run it up the rpm range it starts to get hot 230-240 outside temp 77. Replaced the water pump thermostat and the radiator with a larger dewitts. I also followed the steps to remove air from the system. The larger radiator was no improvement. Air dam is in place fans work and run on high. The only way the temp will come down is if you run the heater. Any suggestions would be appreciated.
Old Sep 12, 2013 | 06:41 PM
1999corvettels1's Avatar
1999corvettels1
What does it do if you just start the car and let it idle, and come up to temp slowly, such as parked in the garage?
Will it overheat then, or just when you are out driving it hard?
No ideas really, but thought this would "bump" the thread and get others to think of ideas.
Old Sep 12, 2013 | 06:53 PM
Yellow03ZO6's Avatar
Yellow03ZO6
I think stock mine ran around 225 maybe a little more. Does any warning lights come on?
Old Sep 12, 2013 | 07:31 PM
onlyavette's Avatar
onlyavette
Coolant temp sensor?
Old Sep 12, 2013 | 07:49 PM
joes2001's Avatar
joes2001
Hi, I know that you said no water in oil but it could be leaking head gasket and letting in combustion to the cooling system. Hope not as these engines don't have a high head gasket failure but just saying it as a possibility.
Old Sep 12, 2013 | 10:23 PM
Chicago1's Avatar
Chicago1
http://forums.corvetteforum.com/c5-t...turned-on.html
Old Sep 12, 2013 | 10:56 PM
silas1234's Avatar
silas1234
I'm going to try the crossover tube tomorrow. All my other vettes run 220 max more like 200.
Old Sep 14, 2013 | 09:37 PM
silas1234's Avatar
silas1234
That worked I'm going to do some driving in it tomorrow and see how it does.
To Overheating help
