RFA Serial Data Buss?
Old Sep 20, 2013 | 11:39 AM
Corvette_Ed's Avatar
Corvette_Ed
Default RFA Serial Data Buss?
So I would not continue to butt into another's thread I am starting this one to get some clarification on the following response to my problem of the BO RFA throwing 1016, 1064, and 1096 codes since I bought my car last year:
I doubt that the codes are from the aftermarket FOB. U1016 says the RFA is unable to communicate to the PCM, U1064 is RFA unable to communicate to BCM and U1096 is RFA unable to communicate to IPC. Most likely a Serial Data Buss issue at the RFA. But I could be wrong.
What and where is the Serial Data buss and how do I fix it, or test to see if this is indeed the cause of these codes coming up constantly? Could this possibly be caused by poor grounds?
Old Sep 20, 2013 | 12:47 PM
dadaroo's Avatar
dadaroo
I would not think it is a FOB issue since the TPMS uses the RFA also. Look at the RFA and make sure the connection there is good. There is a ground for that also but not at home now with the FSM to help ID the location. The RFA is behind the driver in the trunk.
Just saw that 8VETTE7 made a post while I was responding. His info should get you going for now.
Old Sep 20, 2013 | 12:55 PM
Corvette_Ed
Originally Posted by 8VETTE7
There is a presence of the Serial Data Buss at every sensor in the car.
The sensors communicate to the BCM, PCM, IPC etc by encoding messages on the "buss". In the passenger footwell is a pair of connectors that "star" out the buss to various sensors. Courtsey of Bill Curlee here are a couple pics of those connector(s):
Courtsey of that same gentleman here is a wiring diagram that goes along with the above connector:
Could your problem be a "ground issue"? Certainly could. Ground would most likely be for the RFA.
Here is some ground info I have collected over the years:
http://forums.corvetteforum.com/c5-t...locations.html
http://forums.corvetteforum.com/c5-t...tion-long.html Post #1
Thank you for this information.
It looks like I have some work to do. Is the ground that is showing in the center of the rear hatch area in the large storage area? That one is going to be a problem for me as I have a custom-built subwoofer enclosure there.
Old Sep 20, 2013 | 12:56 PM
Corvette_Ed
I don't have a trunk; where is it located in a coupe?
Old Sep 20, 2013 | 02:38 PM
dadaroo's Avatar
dadaroo
You know that thingy that opens up at the back of the car? It hides the trunk.
Old Sep 20, 2013 | 03:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look behind the plastic interior closeout cover on the drivers side (the thing with the rear speaker on it)
Old Sep 20, 2013 | 04:50 PM
Corvette_Ed
Thank you for this visual aid Bill. Sometimes us older folks just need a little extra help.
I'll dig into this next week after the rain lets up. Those three codes are the only ones that pop up on a regular basis and it would be nice to get rid of them.
Old Sep 20, 2013 | 04:53 PM
Corvette_Ed
It doesn't hide anything; it's got a big window on it.
I get what you're saying, but I've never called that area a trunk as it does not have a trunk lid, it has a hatch. Thus, that area has always been called the "hatch area" for every hatchback car I've owned and by anyone else that I've ever heard refer to that area. You're the first I've ever seen who calls it a trunk.
Old Sep 20, 2013 | 05:34 PM
dadaroo's Avatar
dadaroo
I just needed to heckle you. If you read All Corvettes are Red you will find out the designers called that a trunk on all the models.
To RFA Serial Data Buss?
