head gasket replace
If it doesnt correct the leak issue,, NO,, you will NOT have any issues taking off the heads with studs. The heads clear everything!
STUDS are GREAT!When you remove the INTAKE MANIFOLD, you will not be able to fully remove/ extract the two manifold bolts under the cowl. Cut two 3/4" long pieces of 3/16" vacuum line and slip them in under the heads of the two intake manifold bolts. That will allow the bolts to be moved UP so they clear the holes in the cylinder heads and you can easily remove the manifold.
Hope the retorque resolves the leak!!! It does most of the time.
BC
BC
If its only a minor external leak, I would consider a block sealer if the retorque doesnt work. Some of the advanced sealers are a multi step product and dont cause any coolant system damage. I would do all that I can the easy way vise tear it apart!
Having ARP Head studs makes it EASY to check the torque!
NOTE! I would be very careful when you check the head studs in the area where the leak is happening. If you find one stud with very low torques, you could have a stripped head stud hole.
It happens a lot when using the OEM head bolts and usually happens on the two short end head bolts. I have not seen it happen to a block that uses head studs. Just trying to figure out what would cause it to leak after all these years.
Call Tony Mamo and see what he recommends for the gasket replacement if you end up removing the head and why he used what he used and maybe he can also explain why it leaked. If you have to replace ONE head gasket, I would match what is on the other side for sure!
He has a LOT more expierence with the ins and out of engine assembly for performance than I do!
However, if it were me, I would remove the nuts/washers one at a time in sequence and then torque to final value. You essentially have nothing to lose since it is already leaking.
I did a retorque on mine after two heat cycles to ensure I didn't have an issue with the Cometics. I also sprayed them with a light coat of Hylomar prior to installation.
I have a head on my 4th gen Z-28 that has a stripped thread. I hate to admit it, but I tried to shoot a heli-coil in the bad hole, and didn't get the hole at the right angle. Now, instead of a thread that was sort of bad, I have a good heli-coil, but off angle, with the bolt not going in more than 2-3 turns.
I'm going to have to pull at least one of the heads, and I'm NOT looking forward to it!!
