Hard Shifting and Grinding
Old Sep 26, 2013 | 11:11 AM
Vato's Avatar
Vato
Default Hard Shifting and Grinding
For a while now my 6 speed in my 2000 has effectively been a 4 speed, as getting into 3rd or 4th has been impossible without a horrific grinding noise and feel. If I let off the rpm's from 2nd gear I can BABY it into 3rd, then same time to 4th; feeling what I assume are snychros lining up. For commuting this is fine as a 2nd to 5th shift is no problem for the HP I have, however for more spirited driving, like dropping it into 3rd from 4th at highway speeds and punching it (you all know what I'm talking about!) forget it! Bottom line is whats wrong and how much.
Vato
Old Sep 26, 2013 | 02:59 PM
3sACROWD's Avatar
3sACROWD
I agree that it sounds like the synchros are shot. If your tranny isn't already upgraded, I'd suggest steel shift fork, bronze push pads, etc. Check out RPM transmission Level IV or V to get an idea.
I have a Level V from RPM and am happy with the results.
Old Sep 26, 2013 | 03:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have synchro/3/4 gear and or shift fork pad damage. No doubt about it, you need a rebuild.
My choice for a rebuild is Rick Kim ( RKT56) (Forum Sponsor) OUTSTANDING results!
Take it out and ship it to him!
Here are some trans related post for you to take a look at:
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
PS... ragtopws6 = RKT56
Old Sep 26, 2013 | 04:06 PM
Vato's Avatar
Vato
Thanks for the great info! Any idea of costs?
Old Sep 26, 2013 | 04:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Call and discuss with Rick. He will know a lot better than I
Old Sep 29, 2013 | 09:33 AM
RAS6582's Avatar
RAS6582
I'm having the exact same problem with my 02 so I feel your pain dude. I was quoted @ $2,500 to rebuild with a steel shift fork and bronze push pads. That's with them doing all the work.
Old Sep 29, 2013 | 10:20 AM
Vato's Avatar
Vato
That's not bad. I have been using Next Level Performance in Orlando for a few years now, and Mike Norris before that. I should give them a call.
Thanks,
Vato
Old Sep 29, 2013 | 03:28 PM
RAS6582's Avatar
RAS6582
So, the way you make it sound, you have been avoiding 3rd and 4th altogether? Sometimes when I try to shift from 3rd or 4th it doesn't want to come out and feels soooo sloppy that I contemplate not returning. Has that happened to you?
To Hard Shifting and Grinding
