Still overheating-major problem??
Old Sep 26, 2013 | 09:34 PM
heybro's Avatar
heybro
Default Still overheating-major problem??
my 99 coupe is still overheating after pressure test for coolant leak (none found) coolant flush, new t stat, coolant temp sensor, fans checked...etc. So the fans kick on when they should and it doesnt leak coolant. it stays cool at idle but when i drive it she slowly overheats and i am forced to pull over. i had to tow it to freedom chevy in san antonio. any body have any idea?
Old Sep 26, 2013 | 10:25 PM
Macleod52's Avatar
Macleod52
What temp are you hitting?
Old Sep 26, 2013 | 11:32 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
ran into a similar problem after i had replaced radiator hoses.
Turns out that the hose was not twisted in the right position causing an up hill flow and possible "air hammer".
the other common issues is garbage stuck in front of the radiator shroud.
crawl up under it and check for junk stuck in the fins and use a water hose and flush the fins.
Old Sep 27, 2013 | 01:39 PM
heybro's Avatar
heybro
it was maxing out and shutting off. over 260 degrees!! never buy a vette off autotrader
Old Sep 27, 2013 | 02:25 PM
Corvette_Ed's Avatar
Corvette_Ed
As suggested above, clean out your radiator fins.
Did you follow the proper procedure for bleeding the air out of the coolant system when you flushed out the system?
Old Sep 27, 2013 | 02:31 PM
3sACROWD's Avatar
3sACROWD
Have you checked to make sure the radiator is not plugged? You said you had the system flushed but did they verify the radiator is functioning properly?
When I was a kid, I killed a car because the radiator was plugged and my idiot light didn't work. I had overheated and could not find the cause so I changed the coolant and oil. After filling with new coolant I verified flow by opening the cap on the radiator. It was flowing great. What I didn't know to do was feel the face of the radiator to verify the whole radiator was an even temperature. The lower half of the radiator was plugged so I only had half the cooling efficiency.
Get your engine up to operating temp and then feel the front of the radiator from top to bottom. (be careful not to burn yourself) If a section of radiator is plugged, it will be noticeably cooler than the rest.
Just a thought...
Old Sep 27, 2013 | 02:53 PM
runner140*'s Avatar
runner140*
Default I'll bet you a buck.....
I'll bet you....that you have either a clogged up radiator (needs to be pulled out and pressure sprayed clean). or you have an air bubble....in the system. Both are easy fixes.
Old Sep 27, 2013 | 05:55 PM
Paul 75 L82's Avatar
Paul 75 L82
Toss that rad, buy a new one for $200.
Old Sep 27, 2013 | 06:20 PM
KenShores's Avatar
KenShores
I had plugged radiator, from the coolant turning to gel. But I had opposite over heating problem. Ran cool on highway but over heated fast sitting in traffic. A presser flush on radiator cured me, luckily.
Old Sep 28, 2013 | 02:52 PM
heybro's Avatar
heybro
well dealer called and said the crappy autozone tstat i used was part of the problem but the major thing was that the radiator cradle was all jacked up under the car and wasnt allowing air to flow up during highway speeds. he said it was bent and missing all kinds of hardware so that was blocking air flow. had to get the parts from detroit and the whole thing is gona cost a pretty penny. only had the car 45 days and havent even got a chance to enjoy it. lesson learned to have a professional do a complete pre purchase inspection on the next one...bummer
Old Sep 28, 2013 | 09:42 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
You sure the air damn was not just needing to be adjusted?
Take your vette up to Biffs Burgers on Toperwein on a friday night behind the waterburger.
Go talk to all the other guys with vettes and have em take a peek.
To Still overheating-major problem??
