DIY Intake
Old Oct 3, 2013 | 06:07 PM
Yoav G's Avatar
Yoav G
CorvetteForum Editor
Default DIY Intake
Hey guys, here is a link to a DIY intake mod... good for about 10-15hp and doesn't really cost anything...
Old Oct 4, 2013 | 09:25 AM
Jims79's Avatar
Jims79
It should work. But it looks like you would be cleaning/replacing filters weekly. Why not just put on a CAI an do it right.
Old Oct 4, 2013 | 04:44 PM
C5Natie's Avatar
C5Natie
The good ol zip tie mod. Pretty old. Filters wont get that dirty because no real cold air gets in there. You would need to open the rad shroud for that. That dyno dont really matter since the car will be sucking in hot air as you drive around.
Old Oct 5, 2013 | 03:51 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Dyno is done with the hood open and a fan under a shaded garage.
Close the hood and sit in traffic and you are worse off than when you started with the shield.
Old Oct 7, 2013 | 07:43 AM
SuperTom's Avatar
SuperTom
look into flip-tie if you want a free intake. I had it and it was great. Moved on to Vararam but not much difference in performance daily driving unless you drag race 24/7
Old Oct 7, 2013 | 01:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
5-7 hp on a good day!! Dont fall for the hype!
Old Oct 7, 2013 | 03:45 PM
zeevette's Avatar
zeevette
I don't see how opening up the airbox is going to make the filter get dirty that much more. The air moves through that area at any speed other than a crawl, so unless you go with a vararam, which forces the filter to use only outside the engine compartment air, the only differences are in filter flow, not engine heat. K&N filters are all cleanable; no need to replace. They make one that attaches directly to the MAF, basically a Blackwing, without the expense.
Old Oct 8, 2013 | 10:26 AM
CactusCat's Avatar
CactusCat
What? At least 30 HP!!
Old Oct 8, 2013 | 09:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHAT!?! For a dam air filter???????
I hope you are just kidding correct???
Old Oct 8, 2013 | 11:33 PM
CactusCat's Avatar
CactusCat
Hahah, of course I'm kidding. However, the window decals I put on added at least 50hp. No chit man!
To DIY Intake
