ARH 1 7/8 Header Install 2002 Vert
Started on mine about 7:30 last night.
Removed coil covers and coil packs from both sides. Removed valve cover from right side.
Removed left side ex manifold. (15.30 lbs)
Removed right side ex manifold. (15.0 lbs)
Removed stock pup cats, cats and aftermarket X pipe. (43.60 lbs)
Installed left side 1 7/8 header from the bottom. (12.20 lbs)
Installed right side 1 7/8 header from the top. I had to loosen the motor mount and raise the engine as far as it would go. (12.20 lbs)
Installed the ARH high flow cats and 3" X pipe. (27.7 lbs).
Also reinstalled all 4 O2 sensors.
Test drive at 2:30 am, top down, 70 degrees outside, love the sound through my previously installed Z06 Ti mufflers.
Total install time 7 hours.
Total weight savings: 21.8 lbs.
The A/C line is very close to the right side header. I don't see how bending it will create more clearance. Anybody have a before and after picture of how they bent the A/C line?
I kind of expected it with an 1 7/8 header. I'm getting ready for the YSI install.
It wont add a lot of HP but it will make the throttle response a little better. With the proper tune you will see that power and economey come back and may even get a lot better.
Enjoy the extra horses.
We average 1-1.5 hours installing ARHeaders, but that's with 2 techs and completing 100's of installs.
Good point on the weight savings. that's quite a bit.
Nice work
Removing the battery shroud makes it easier to see what's going on. It only takes about 30 seconds to remove. There is a plastic fastener on the cowl, another on the opposite end on the wheel well and perhaps there was originally a speed nut on a stud at the bottom of it near the middle of the bend.
