Wiper cam
Old Oct 16, 2013 | 06:21 PM
Boss75's Avatar
Boss75
Default Wiper cam
my windshield wipers have been stuck straight up on my windshield.after some searching and I checked my udders and they were a little clogged but there wasn't any standing water. I went ahead and replaced the motor and I'm having the same problem. After some investigation I discovered there is a little lever under the cam that isn't catching on the stop to push the wipers down into the park position. Now I need to figure out what part to order to fix this sucker. Oh how fun this is...
Old Oct 16, 2013 | 07:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The procedure is in the service manual. I can give it to you but I can not figure out how to send it with the diagrams.
Wiper Motor Crank Arm Replacement
J 39232 Wiper Transmission Separator
J 39529 Wiper transmission Installer
Removal Procedure
Remove the wiper arms. Refer to Wiper Arm Replacement .
Remove the air inlet grille panel. Refer to Air Inlet Grille Panel Replacement in Body Front End.
Using the J 39232 , disconnect the wiper transmission from the wiper motor crank arm.
Remove the wiper motor crank arm screw.
Remove the wiper motor crank arm from the wiper motor.
Installation Procedure
Install the wiper motor crank arm onto the wiper motor.
Position the park latch 4 - 5 mm (0.16 - 0.20 in) from the park tab.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the wiper motor crank arm screw. Tighten
Tighten the screw to 15 N·m (11 lb ft).
Using the J 39529 , connect the wiper transmission to the wiper motor crank arm.
Install the wiper motor module. Refer to Wiper Motor Module Replacement .
Install the air inlet grille panel. Refer to Air Inlet Grille Panel Replacement in Body Front End.
Install the wiper arms. Refer to Wiper Arm Replacement .
Inspect the wipers for proper operation.
Document ID# 821303
2002 Chevrolet Corvette
Old Oct 16, 2013 | 10:05 PM
Boss75's Avatar
Boss75
Thanks for that Bill. Looks like that will be the next item of business for the vette. I found this picture on here and studying it shows me that the parking pawl is the piece now that isn't working right. Had I seen this pic before changing the motor it would have saved me two hours and about 60 bucks
In reality it would be nice if I could figure out a way to fix just the parking pawl since that's the only problem. I just don't have a reference for how it pushes out to press against the stop.
Old Oct 17, 2013 | 10:25 AM
ericdwong's Avatar
ericdwong
Try this thread. I had to adjust mine too:
http://www.digitalcorvettes.com/foru...d.php?t=121213
Old Oct 17, 2013 | 11:54 PM
Boss75's Avatar
Boss75
That's a great thread. Unfortunately it looks like I'm going to just have to replace the transmission. The parking pawl is free swinging and won't mate up with the parking stop and I have no reference on how to fix it, if that's even possible.
To Wiper cam
