Ground Stud
Old Oct 21, 2013 | 03:25 PM
Matt32olb's Avatar
Matt32olb
6th Gear
Default Ground Stud
I was working on cleaning my grounds on my 1999 FRC Corvette. Specifically the one on the drivers side. When removing the bolt and nut. Of course the stud/bolt broke. I went to my local Chevy dealership to see if I could get the part. I was told they do not make the part anymore. It seems as though it also needs to be copper. I searched online and found some hits although it seems the part is out of stock. Part number 10278878. Any ideas or help would be great. Thank you!!
Old Oct 21, 2013 | 03:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MAtt
I snapped two studs off on my 98 coupe.. Just find a self tapping metal screw and drill a pilot hole in the frame and remove all the rust and damaged metal where the Ground connector will ground to.
I used a dremmel tool and a small burr and smoother out the area. Drilled the hole and socked down the screw1 FIXED!
I got the screw from home depot. They also sell them at any home electrical supply house
As long as theres a good solid connection to the frame, the system isnt pickey on how and what you use to connect it.
Bill
Old Oct 21, 2013 | 03:50 PM
WKMCD's Avatar
WKMCD
Originally Posted by Bill Curlee
MAtt
Bill
Exactly what I did.
Old Oct 21, 2013 | 09:26 PM
Matt32olb's Avatar
Matt32olb
6th Gear
MAtt
Bill
Thanks, I will be doing that this weekend. Out if curiosity do you have a picture of when you finished? Thanks again for the help
Old Oct 22, 2013 | 04:12 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I dont have a picture of the G-101 repair but i do have G-401 (fuel Gage and tail light ground stud repair) in the drivers side rear fender well:
Old Oct 25, 2013 | 11:13 PM
ace147's Avatar
ace147
The next best way to repair is with a rivet stud from mcmaster carr or similar. Requires a special tool.
To Ground Stud
