Headers- 1 3/4", 1 7/8", or 2"... why??
Old Oct 24, 2013 | 09:56 AM
dork's Avatar
dork
Default Headers- 1 3/4", 1 7/8", or 2"... why??
From what I've read, these three sizes seem to be the (only?) most common sizes for headers. It seems to me that larger would be better, allowing exhaust gases to be evacuated faster. (I thought keeping some "back pressure" to enhance engine performance was a myth.)
1) What determines which size you purchased for your own use?
2) Why 3 sizes?
3) What's the GM OEM diameter on a c5 z06?
Thank you.
Old Oct 24, 2013 | 10:16 AM
Kreeess's Avatar
Kreeess
2) Why 3 sizes?
Thank you.
it benefits those who opt for bigger cams and blowers allowing for more and faster air flow since our engine is technically a big vacuum
Old Oct 24, 2013 | 11:00 AM
bdanyluk's Avatar
bdanyluk
Here's how I see it.
- 1-3/4" if you keep your engine stock
- 1-7/8" if you plan to add heads/cam or supercharger/turbo
- 2" if you plan on making 800hp+
Just my 2 cents......I personally have 1-7/8" (2006 C6 w/LS2) and my engine is stock. Someday I might put on heads/cam that's why I didn't get 1-3/4, so I only have to buy one set of headers in my life. It ain't cheap!
Old Oct 24, 2013 | 03:22 PM
ZZ06's Avatar
ZZ06
There are guys here running both 1 7/8 and of course the 1 3/4 headers with just basic boltons and a cam. You will get great numbers with both. Its been said however, that with stock cubes (especially 5.7) and use of the 1 7/8, that there is a slight torque to hp trade off in the rpm band. That being said, im pretty sure LG posted the numbers years ago and there wasn't a difference in low end tq. Hp was better by 10+. Really just purely preference. Now, IMO would NOT go near a 2" unless you have 400+ ci as I can really see your tq just falling on its face. That's A LOT of air to move out of a 346ci, even with FI. Its just simply not needed. The smaller sizes are tried and proven
Old Oct 24, 2013 | 03:49 PM
sami85L98's Avatar
sami85L98
#3 post nailed it, i would go 1 7/8 ARH headers catted, and wont turn back. I have SW 1 3/4....wont recommend, Kooks you had to be above average mechanically inclined, OBx.....all so so. ARH hands down literally.
Edit: i have installed all the above mentioned headers.....personal experience. ARH was the best and in fact i did install 2" ARH as well....fit like glove.
Old Oct 24, 2013 | 03:59 PM
vettenuts's Avatar
vettenuts
Tri-Y or 4 to 1 design? Z06 (and LS1) are Tri-Y design.
Old Oct 24, 2013 | 04:53 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
There's a fair amount of science that goes into it, but generally you want to size the primary tubes in order to maintain a certain flow rate. This allows the headers to actually promote scavenging the cylinders - which helps pull out ALL of the spent gases and, depending upon cam overlap, it can help draw in the fresh air/fuel mixture too.
That is why, when a header is sized too big for an engine, you lose the low end torque...there is no scavenging happening due to the low flow rate of the exhaust gases.
Hope that helps...
Old Oct 24, 2013 | 05:21 PM
s'noJob's Avatar
s'noJob
Here's something to consider as well. Two inch headers put heat closer to other engine components than smaller headers. And if that becomes a problem, you have even less space to wrap heat insulation around the headers.
They also make it that much more difficult to access the components. If you don't mind moving headers around to get to other engine parts, go for it.
As counter-intuitive as it sounds, it almost makes sense to buy the smallest headers that will do the job for your particular application. Too much header creates headaches elsewhere.
Old Oct 24, 2013 | 06:43 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
LG's did tests on 1 3/4" and 1 7/8" headers on our 346ci motors.
They determined that the larger 1 7/8" headers lost low end torque compared to the 1 3/4".
Anthony told me that the 1 3/4" headers are best for stock 346ci, or full heads cam setups.
Supercharged cars or larger displacement motors will benefit from the larger 1 7/8" headers.
Contact Anthony at LG's and he can fill you in.
Toque
Old Oct 24, 2013 | 07:39 PM
PRE-Z06's Avatar
PRE-Z06
Depends on where you want to make the most power and how much you plan to make, here's a comparison I did...
http://forums.corvetteforum.com/perf...s-results.html
Old Oct 24, 2013 | 08:03 PM
c5austin's Avatar
c5austin
If you ever plan on doing a blower just get the 2" and be done, wouldn't want to do headers multiple times. And if you did the blower you don't have to worry too much about torque problems, more like traction problems
Old Oct 25, 2013 | 11:57 AM
ZZ06's Avatar
ZZ06
Toque
Ohhh I thought I remember seeing that chart....I could've swore the tq was the same with higher hp???
Old Oct 25, 2013 | 12:32 PM
Blow Torch's Avatar
Blow Torch
True, but unless you RACE all the time, you will spend FAR more time out of boost than in. The smaller tube (1 3/4 isn't really small) promote low end torque better than a 2" does, and will still make some crazy HP #s.
To Headers- 1 3/4", 1 7/8", or 2"... why??
