fuel pressure problem on 2001
Old Nov 18, 2013 | 02:40 PM
Warranty Auto's Avatar
Warranty Auto
2nd Gear
Default fuel pressure problem on 2001
changed fuel pump on left tank and siphen asm. on right tank turn key on and still only have 13 lbs at rail. crank eng and it drops to 0 lbs. checked groun strap on back of rail and its in good cond. were to next ?
Old Nov 19, 2013 | 06:35 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Try a new fuel filter. The filter is part of the pressure regulation system.....
Old Nov 27, 2013 | 03:12 PM
Warranty Auto
2nd Gear
replaced filter with oem checked all grounds still no pressure. will pump up to only 7-9 lbs when key is turned on and will start for a second or two untill fuel is GONE ? what the heck is going on ? going nuts trying to figure this out
Old Nov 27, 2013 | 09:11 PM
69's Avatar
69
Cruise-In VI Veteran
Pull the codes and post them up. also have you checked the voltage to the fuel pump connector?
Goose
To fuel pressure problem on 2001
