crazy gauges?
Old Nov 18, 2013 | 10:12 PM
c56.0hh's Avatar
c56.0hh
Default crazy gauges?
01 c5 vert,crank up fine drive down road ,hear a ding ding,check gauges light is on and gauges are pegged out!! pulled over turnd off crank up gauges fine,until about 5 min and does it again,car is running fine tho while this is happening! any ideas,pleas chime in!thanks
Old Nov 19, 2013 | 12:08 PM
JetMechZ16's Avatar
JetMechZ16
Codes? Pull your codes and post them.
Old Nov 19, 2013 | 02:08 PM
CactusCat's Avatar
CactusCat
Sounds like the problems Bill Curlee has described with ignition switch problems. Crazy, erratic gauges is one of the symptoms. Did you look at your codes to see if anything was there? If so, post the codes and we'll get started on this. If not, then clear your codes, do some driving and read the codes immediately after it occurs. Many threads/examples on how to read the codes on the DIC.
Old Nov 19, 2013 | 10:57 PM
BigGun's Avatar
BigGun
Check this link. It is the same problem you are having now. http://forums.corvetteforum.com/c5-t...-there-is.html
Old Nov 20, 2013 | 07:58 AM
c56.0hh's Avatar
c56.0hh
thanks guy,will look into thos weeknd!
Old Nov 20, 2013 | 10:21 AM
David Shiel's Avatar
David Shiel
Default Also sounds remarkably
like mine. Still have not found the cause. Codes were all 1096 com codes such as RDCM, LDCM, HVAC, Radio,etc . Bill , Lionel and Sam have been working on it with me on it. Follow the post here. Search " I am stumped." Some 60 posts so far.
Dave
Old Nov 20, 2013 | 07:19 PM
c56.0hh's Avatar
c56.0hh
thanks for the info will check all that with mine this weekend,thanks!
To crazy gauges?
